Which Brake and Clutch Fluid do you use?
Started by Bbrent, August 10, 2008, 08:33:19 PM
Bbrent
What do you use? Can you use brake fluid for the clutch?
they are the same fluids as far as our bikes go. Anything but dot 5.
hooligan machinist
I use plain old DOT 3. But because it's prone to absorb moisture i change it every 12 to 18 months.
cell # (931)-316-2020
mmakay
Cheap and frequently changed is better than old and expensive any day.  You only need more expensive fluid if you manage to boil it.  (If you don't know what that's like, you've never done it! :) )
- Mickey
SP3
Cheap name brand DOT 3 or 4. No need for high buck stuff for street riding.
1991 851 SP3
1966 250 Monza
1999 Monster 900 City
also dont buy big bottles. The seals are never perfect and they tend to leak air, which leads to moisture build up in "new" fluid. You can try to pick up some blinker fluid too. It'll give you a better feel.  [thumbsup]
