Quick Sprocket Question
Started by sleeperbold, August 11, 2008, 12:57:57 PM
sleeperbold
I have a 2005 S2R-800 w/ 15k on it. My chain has a few tight spots and I decided to change it out but was told to do the sprockets at the same time. No worries, but here's the question: Is it better to go one tooth down in the front or go up two teeth in the back. I'm leaning towards two more teeth in the back. Additionally what are the stock teeth 40,41,42? So I know what to order. Argh! I am going kinda nuts dealing with this. Thanks for the help guys and gals. - B :)
mmakay
If you are changing sprockets anyway, go up 3 teeth in the rear.  Chain and sprocket wear will be a little better than going to the 14T up front.
- Mickey
silentbob
You don't need to change the sprockets with the chain unless they are hooked or you just want to change the gearing.  As for the 14 vs 15 tooth debate, here is a good read.
http://ducatimonsterforum.org/index.php?topic=6523.msg122364#msg122364
sleeperbold
NuTTs
14T - 43T always worked well for me.
I would go with a larger rear sprocket. But, 2 teeth will only make a slight change...
Manx
I went up 4 on the rear (15/43? I think) works well for me.
My bike is a 2003 M1000Sie
S2R800 has a 42 tooth rear stock....
sleeperbold
bbot5000
Quote from: NAKID on August 11, 2008, 02:46:07 PM
I have a 05 S2R800 and it had a 41T stock. I now have a 15/44 quick change setup.
I haven't notice much of a difference, but that is because I have gained like 30lbs.  :'(
Quote from: bbot5000 on August 11, 2008, 05:23:47 PM
That's odd. My 05 S2R Dark was 42, my 1000 was a 41...
bbot5000
Quote from: NAKID on August 11, 2008, 05:50:35 PM
Yeah I had always thought my bike was a 42T too, until someone pointed it out that it was a 41T when I was trying to sell it on ebay.
BTW I have an aluminum 45T quick change, only mounted but never used, for sale if anyone is interested.
numbskull
Quote from: mmakay on August 11, 2008, 01:08:57 PM
+1
This is the way to go according to my local Ducati techs.
COWBOY
#14
Quote from: bbot5000 on August 11, 2008, 08:23:30 PM
From the 2005 S2R Manual
15 Front
42 Rear
104 Link 520 chain.
For what it's worth Chris at Ca-Cycleworks recommended going up 1 on the rear as opposed to down 1 on the front.  It's more responsive since and I'm happy there.  I can't imagine the pull out of 1st you'd get by going +3 on the rear.
2005 S2R -- Mods installed: DP termi full racing kit, ST4 Forks, S4R rear shock, 999 Radial Brake and Clutch MCs, 4 pot Brembo Calipers, 320mm Snowflake rotors, SBK Quick change carrier, 43T rear sproket, Tomaselli Clip Ons, Cyclecat Frame Sliders, ASV Levers, zero indicators, Supernova taillight
