help needed.wiring diagram .turn signals s4 2002.
Started by pigmy, August 11, 2008, 07:48:53 PM
pigmy
cannot find turn signal unit.suspect its in the instrument cluster.does anyone have a wiring diagram plse...
my indicators do not work nor does the odometer.checked everything else.
herm
Yes, the relay is in the instrument cluster.
If the speedometer works, then the sensor at the rear wheel and all the associated wiring and connectors are OK.
You can try unplugging and replugging the connector on the back of the cluster, but I suspect your cluster is sacked.
pigmy
thank you herm and nick.looks like we might try and bypass the cluster by hooking up some sought of indicator circuit.if not
then i guess  $1400 is in order...pigmy
