Duc Fever
« on: August 12, 2008, 07:52:55 AM » |
Anybody replaced the stock handgrips with aftermarket ones? Is it easy? Looking for recommendations, tips/tricks etc. for doing so. Pics are great as always!
"You have not converted a man because you have silenced him" ~ John Morely
« Reply #1 on: August 12, 2008, 08:01:14 AM » |
So I went solo. -Me
Some people call 911..... some people are 911 -Marcus Luttrell
« Reply #2 on: August 12, 2008, 09:36:22 AM » |
+1 on the progrip. I have the triple gel grips on my S2R1k and they are great...
Plus, they're cheap...
2006 S2R1000 2015 Monster 821
hypurone
« Reply #3 on: August 12, 2008, 10:21:47 AM » |
I also run the Gel Pro Grips. Not a big deal to install, just be careful with the throttle side if you use grip glue and have to trim to fit (you most likely will)
'07 S4RS "Testatretta" (In the FASTER color) I'm not totally useless, I can be used as a bad example!
« Reply #4 on: August 12, 2008, 12:27:56 PM » |
All I had to do with the grips was cut a hole for the bar end weights...
metallimonster
« Reply #5 on: August 12, 2008, 12:34:21 PM » |
Okay my second stupid question of the day. Are all grips universal? If not, what size do I need to get? I think it is 7/8 but I am not for sure.
Wherever I May Roam, Where I Lay My Head Is Home 02 620 Dark- High Mount CF Arrows
S2daRk
« Reply #6 on: August 12, 2008, 11:53:32 PM » |
Just installed a pair of progrip superbike gels (open end #780). Great fit; perfect length with no trimming at all. You can easily remove the throttle tube assembly and bring to the store to match up a set of grips. My throttle tube has a dish "cone" shape where it meets the control. It also has a little ridge at the opposite end of the tube. The grips I got accomodated both the dish and the ridge. Many of the throttle grips I saw just had a flat doughnut like the clutch side, those wouldn't have fit well. Also some were a little too short.
zarn02
« Reply #7 on: August 13, 2008, 03:51:16 AM » |
bars should be 7/8. i think most everything is, with the exception of harleys, and maybe a few of the more enormous japanese cruisers.
Alexandre
Monstro
« Reply #8 on: August 13, 2008, 03:54:20 AM » |
rizoma billet grips too
Valor
2003 Monster 620 Dark
« Reply #9 on: August 13, 2008, 03:55:57 PM » |
Carman
« Reply #11 on: August 13, 2008, 07:18:44 PM » |
I was going to try the compressed air trick to get mine off, will let you know how it works when I get home in a couple weeks
Carman '07 S4RS
jesse370
« Reply #13 on: August 13, 2008, 07:40:26 PM » |
carman, the compressed air trick is how bicycle mechanics install grips on bikes when they assemble them.
In my previous life I have exploded a few and fired a few off a set of bars like a bullet.
White S4Rs | Ducati Performance Chip | Termi's | Hyperpro side mount damper | Motowheels MW-7000 Slipper | Billet Clutch Cover | Speedymoto Ti Spring Caps | Speedymoto Stainless Springs | STM Frame Plugs | Ducati Performance Seat | CRG Roll-A-Clicks
