DIY V2
Started by DRKWNG, May 07, 2008, 11:44:11 PM
teddy037.2
if those wheels are the same axle dia as your bike, that's a good start.
I have heard that the steel swingarm will have clearance issues when going to a wider rear, and the al arms are made for it...
Xerxes1769
#151
So the problem would be the tire and not the rim?  The wheel will have the same axle diameter (i believe...)...could I just buy a smaller tire say a 170 (would that even fit)?
teddy037.2
yes, more of a tire/chain thing, than wheel/swingarm thing
I think.
MadDuck
Got it.  I would like to try to put them on, but I know the tank has to come off.  It's cool if you don't feel like spending much time on it.  Over all I figure it would take at least two, maybe two and a half hours, to get it all done; without counting distractions and our usual babble sessions...
MadDuck
Good to go if you are.
What time are you heading down? Around elevenish?  I'll print out the instructions that I found online so we will have that to go from. I'll try to email the link to you as well.
But coffee comes FIRST!!
MadDuck
Quote from: DRKWNG on December 26, 2009, 07:34:02 AM
11ish is good. G & I are off to breakfast now.
Xerxes1769
Back to the wheel subject...is this all it takes to mount the 5.5" wheels on to my bike?
http://ducatimonsterforum.org/index.php?topic=25054.0
Just this spacer
Brutale
Ok, I picked up the Rizoma fluid reservoirs (in black) from the BM who ordered them but couldnt use them.  How involved is it to replace them, add new fluid, and bleed them??
'07 Sport 1000, Black, slightly modded
MadDuck
Not that hard but harder than you might think. You may need new hoses & clamps.
eltristo
That sounds familiar.  Let me know when yer looking to do it and I can replace my hoses, etc at the same time.  maybe...
I gave you that extra bit of brake hose right?
eltristo
Quote from: DRKWNG on January 03, 2010, 01:24:41 PM
It's stilli in the bag with the levers, which I have some cash for btw.  I just need to decide if it's worth it to me to buy a second caliper and rotor before installing.
eltristo
Possible caliper development:  There's a set of 05 620 calipers for sale with rotors - black brembo.  They'll fit, but are they drastically different than the goldlines?  Are they goldlines painted black?  If they are inferior, would I still be better off with two of those vice the one I've got?
