November 23, 2024, 06:19:59 PM *
News: Please Help
Author Topic: Installing DP Adjustable Levers  (Read 2236 times)
Xerxes1769
2012 Ducati 1199 Tri 1975 Yamaha YZ125
« on: August 12, 2008, 01:42:39 PM »
Okay so I got the DP levers from SS and wondering how hard are they to install/adjust?  Also been looking around but can't seem to come up with any good info/instructions...This is what I found http://ducatimonsterforum.org/index.php?topic=8549.0 any info (torques, things to lookout for, etc.) will be appreciated...replacing them doesn't seem too complicated but adjusting them has me worried don't want to end up going through someone's windshield cause i couldn't stop or not being able to shift from first...(BTW I'm replacing both clutch/brake levers)
Thanks!
MadDuck
The anti-
« Reply #1 on: August 12, 2008, 03:05:15 PM »
I haven't replaced levers. Some might be harder than others. How much would South Seas charge to install them?
One thing I have noticed about DP parts is that they never seem to come with instructions. I guess they assume the buyer knows what they are doing or that a shop tech is going to do the work.
« Reply #2 on: August 12, 2008, 04:56:00 PM »
HOLY SHIT!!  Mike lives!!   Grin
Sorry, don't have anything constructive to add here, just had to inject a little misplaced excitement.
Xerxes1769
« Reply #3 on: August 12, 2008, 08:45:08 PM »
Work has been a b**ch hence I have not been able to meet you guys for any of the JJ rides...I bought the seat cowl and the levers and so far no luck on installing either of them, the levers turned out to be more complicated than the previously thought (I'll have to do some more research and see...) and the cowl didn't not come with brackets so I ordered those from www.monsterparts.com so hopefully they'll be here next week...also saw these http://ducatimonsterforum.org/index.php?topic=8573.0 and was thinking about getting them but not sure how a chrome exhaust would look on a dark monster (or even if they would actually fit)...
« Reply #4 on: August 12, 2008, 10:48:28 PM »
NO!!
You are not allowed to put Vance & Hines pipes on your Monster!
teddy037.2
« Reply #5 on: August 13, 2008, 01:44:51 AM »
as long as the pivots are the correct size, they'll bolt right up. the coffins use the large hole pivots.
adjusting is pretty straighforward, but the main issue you'll have is getting around the clutch safety switch. the OE lever has a tang that extends under to click that switch when you pull the clutch in... you'lll see it bolted underneath the clutch master cylindar
there's a couple of ways to bypass it completely. they way I did was pretty much... free...
