December 19, 2024, 06:41:37 AM *
Pages: 1 [2]   Go Down
Author Topic: Bonneville  (Read 4374 times)
mattyvas
« Reply #15 on: May 09, 2008, 04:09:54 AM »
It's all about the post...
Dockstrada
« Reply #16 on: May 09, 2008, 12:41:42 PM »
Im a full member already have some respect co::
3 stars read them and weep  Cry
« Last Edit: May 09, 2008, 12:47:33 PM by Dockstrada » Logged
If I wasn't who i was, I wouldn't be who I am !
monstermick58
« Reply #17 on: May 09, 2008, 10:06:30 PM »
It seems to me that you have to check your coil/points/leads. A shitty coil will either give you no spark or an orange dirty spark, one way to check it would be a resistance test, do you have a multimeter?
Resistance test as well for the leads.
Check if your points are opening and closing, get the back wheel up, put it in the highest gear, and rotate the back wheel while looking at the points.
I dunno what else. Undecided
Quite sound advice but, if you are running shitty old plug leads, pull the spark plug caps off and hold the lead about 5mm off the head (keeping clear of the spark plug hole) and give it a kick, if it sparks, the plug caps are buggered, I take it that you have no spark at all, with that I mean on both cyclinders?
OK done all that now go and check points, condensers etc....
        Mmick
BadBoyBubby
You're a sexy woman Flo
« Reply #18 on: May 10, 2008, 04:18:13 PM »
Maybe timing? It may be so far out that it just won't fire. I once put the timing back together in a 350 Desmo 180 degrees out - very hard to start - and when it did it almost blew my head off with the backfire.
This signature is forged.
Pages: 1 [2]   Go Up
