April 28, 2024, 10:05:04 PM
OZ monsters
Bonneville
Topic: Bonneville (Read 4012 times)
White Lion
Bonneville
May 08, 2008, 02:11:32 AM »
Guys, the bike is near 100%cleaned and polished. New/charged battery, new fuel, new oil, new gearbox oil, cleaned spark plugs(Slightly carbon fouled, not much though). Bike won't kick over though. Need some help guys.
It just doesn't seem to be 'lighting' up. Front headlight works, so i know the battery is good. Any advice will be greatly loved.
co::
Hugh
Dockstrada
Re: Bonneville
May 08, 2008, 02:15:04 AM »
Quote from: White Lion on May 08, 2008, 02:11:32 AM
co::
Hugh
Have you checked the spark
If I wasn't who i was, I wouldn't be who I am !
Re: Bonneville
May 08, 2008, 02:17:35 AM »
First check to see you're getting sparks - pull a plug out, clip the lead back on, and hold the metal body of the plug against a solid bare metal bit of the engine, then check its got a good bright blue-ish white spark when you hit the starter.
Air, fuel, compression, and sparks are all you need to kick it over - you just need to find which one isn't right.
I could come over Sunday (or possibly Saturday afternoon) if you've got the weekend off...
big (curse you Vince, you beat me by 91 seconds!)
my personal website
my less personal (I'd stop well short of calling it "professional") web site
Dockstrada
Re: Bonneville
May 08, 2008, 02:21:14 AM »
Quote from: bigiain on May 08, 2008, 02:17:35 AM
Im am man of very few words
Last Edit: May 08, 2008, 02:28:02 AM by Dockstrada
White Lion
Re: Bonneville
May 08, 2008, 02:31:04 AM »
Big, will give the spark thing a go in the morning. Thinking the fuel may be blocked 'lower' down in the sytem. I know the fuel tank isn't blocked as both the taps run perfectly. Will pull all the hoses tomorrow to see if there is a problem.
I feel it is either the spark or the fuel. Can't see any reason why the air would be restricted, and the engine is in great condition so i don't think there is a compression problem(Obviously a re-build will get more though)
Hope it's just the sparks...
Hugh
PS:Rapid response boys!! Thanks
Dockstrada
Re: Bonneville
May 08, 2008, 02:40:03 AM »
Quote from: White Lion on May 08, 2008, 02:31:04 AM
Hugh
There you go big you got the credit wt:
White Lion
Re: Bonneville
May 08, 2008, 02:43:03 AM »
Ooooh, sorry Dock. Didn't mean to give you the shoulder.
Dock, will try the spark thing in the morning
Hugh
Dockstrada
Re: Bonneville
May 08, 2008, 02:44:14 AM »
Quote from: White Lion on May 08, 2008, 02:43:03 AM
Hugh
No sweat Lion iv got big shoulders
goldFiSh
Re: Bonneville
May 08, 2008, 02:26:55 PM »
Quote from: Dockstrada on May 08, 2008, 02:44:14 AM
and a new bike?
Dockstrada
Re: Bonneville
May 08, 2008, 02:27:47 PM »
Quote from: goldFiSh on May 08, 2008, 02:26:55 PM
and a new bike?
You got that right wt:
White Lion
Re: Bonneville
May 08, 2008, 03:29:20 PM »
Hmmm...chnaged the spark plugs. Still can't get a spark. Is it a matter of just following them back to the source??
Hugh
Dockstrada
Re: Bonneville
May 08, 2008, 03:36:12 PM »
Have you just changed the plugs or have you also checked for spark like Big sugessted
Super T.I.B
Re: Bonneville
May 08, 2008, 03:52:17 PM »
It seems to me that you have to check your coil/points/leads. A shitty coil will either give you no spark or an orange dirty spark, one way to check it would be a resistance test, do you have a multimeter?
Resistance test as well for the leads.
Check if your points are opening and closing, get the back wheel up, put it in the highest gear, and rotate the back wheel while looking at the points.
I dunno what else.
White Lion
Re: Bonneville
May 08, 2008, 11:13:38 PM »
Big, have to work on both saturday and sunday days. I have all of next week from tuesday lunch to saturday night off though
R_usty
S4RS DUC-23
Re: Bonneville
Reply #14 on:
May 09, 2008, 03:21:35 AM »
Quote from: Dockstrada on May 08, 2008, 02:21:14 AM
But lots of posts wt:
Monster S4RS - Sold....... Looking for a new ride!
