Removing Front Wheel - 1999 750
Started by cyrus buelton, August 15, 2008, 10:40:33 AM
cyrus buelton
Time for some new rubber for the ole' 99 750 Dark.
However, when looking at the front it takes one big ass hex (allen head) tool to get the wheel off.
Does anyone know what size it is?????
1999 M750 (joint ownership)
2004 S4r (mineeee)
cyrus buelton
For anyone that cares, it appears it is a 14mm hex wrench
2004 S4r (mineeee)
hooligan machinist
It's not that we don't care. I was going to mention that i "thought" it was 14mm. Just didn't want to give out false info because i wasn't sure.
cell # (931)-316-2020
uclabiker06
Worst case just try out different sizes and if they don't work return them until you get the right one.  Unless someone can tell you the correct size with certainty.
2006 S2R
2009 Smart
cyrus buelton
Quote from: hooligan machinist on August 16, 2008, 02:32:34 AM
I wasn't meaning that as a negative comment, just stating for the record for future reference, it is 14mm
2004 S4r (mineeee)
hooligan machinist
Quote from: cyrus buelton on August 16, 2008, 01:27:37 PM
It's all good. I was being sarcastic with that statement anyway. Hard to convey over the WWW. [thumbsup]
cyrus buelton
Actually, I was wrong.
It is a 28mm hex bolt!!!
I would love to beat down the genius that decided on that set up, but I must first go on a quest to find one.........
2004 S4r (mineeee)
