October 02, 2024, 04:22:00 PM
Desmotropic
What did you do today?
224
225
226
227
421
Topic: What did you do today? (Read 536430 times)
MadDuck
The anti-
Re: What did you do today?
Reply #3360 on:
January 16, 2011, 07:40:38 PM »
Did the oil change for the 848 yesterday and then took it down to SS for the 2 year service & cam belt replacement. Then back to the shop to tackle an oil filter housing reseal on the 240D ---- got down to the last bolt holding the housing in and then realized that I have to take the steering gearbox out to get the oil filter housing out. One bolt cannot come out because the steering box is in the way. I was in denial for two hours getting to that point thinking that I didn't have to remove that one bolt but noooooooo............ So I put it all back together.
Next week.
Went down to the shop today to have a look at my old Monster. The float needles had let go and filled up the cylinders & the entire crankcase with gas. Almost a whole tank worth of gas. Crazy. I drained everything and cranked over the engine by hand. Seems to be OK but we won't know for sure until the needles are replaced and we get the thing started again. The new owner, or someone, has also managed to strip the vertical cylinder spark plug and the chain hasn't seen any lube in over a year.
Speed 3 Pilot
Geezer
2014 Speed Triple R
Reply #3361 on:
January 16, 2011, 08:54:16 PM »
When do you pick up the 848, and did you supply your own belts?
Today's ride was a two Duc affair...
Life is tough, it's tougher if you're stupid...
Gettin' old ain't for wimps...
You only live once and I feel like I'm running out of time...
MadDuck
The anti-
Reply #3362 on:
January 16, 2011, 10:24:17 PM »
Quote from: Gene V on January 16, 2011, 08:54:16 PM
I'll pick it up next Sat or before, depending. I bought the cam belts from SS a few weeks ago and gave them to Shawn/Will to install.
sta
'95 ZX6R sold '07 Monster S2R1K
Reply #3363 on:
January 18, 2011, 05:38:58 PM »
Yesterday...
I washed my bike, cleaned/lubed chain, and tried to take a look at the rear break actuator. From my ride with Gene on Sunday, Gene noticed my break light stays on even when I am not breaking. I am not sure how much rebound the actuator should do after i release the rear break, but it doesn't seem to do much. Any ideas? Oh, it was definitely the rear break causing the light to stay on, as it works intermittently.
MadDuck
The anti-
Reply #3364 on:
January 18, 2011, 10:41:10 PM »
If I may offer some advice.... This can be caused by a
brake
switch problem and possibly not so much as the brake master cylinder, or brake linkage to the master (what you seem to be calling the actuator) and switch. It is super easy to diagnose and repair. I'll definitely be at the shop on Sat, for sure, so please drop by and we'll sort you out and point you in the right direction, if you want to that is.
Last Edit: January 18, 2011, 10:49:21 PM by mac900
sta
Reply #3365 on:
January 18, 2011, 11:41:02 PM »
Much appreciated. I will come by Saturday. Any preference on the time? I don't want to interfere with your existing plans.
Reply #3366 on:
January 19, 2011, 03:04:17 AM »
Quote from: sta on January 18, 2011, 11:41:02 PM
No such thing as a Saturday plan at BME. It's one of the more random events you'll ever witness.
MadDuck
The anti-
Reply #3367 on:
January 19, 2011, 08:43:39 AM »
Quote from: DRKWNG on January 19, 2011, 03:04:17 AM
No shit. Somewhere in the early afternoon ought to be OK, maybe, possibly..........
As long as I'm home by 6 or 7 o'clock for beers, cigars & jazz then it's all good.
sta
Reply #3368 on:
January 19, 2011, 10:30:45 AM »
Quote from: mac900 on January 19, 2011, 08:43:39 AM
Ah... got it.
Speed 3 Pilot
Geezer
2014 Speed Triple R
Reply #3369 on:
January 19, 2011, 12:00:18 PM »
I should be there to join the fun, which hopefully includes a short ride...autocrossing on Sunday again...
Speed 3 Pilot
Geezer
2014 Speed Triple R
Reply #3370 on:
January 20, 2011, 11:05:59 AM »
Took the SF in to the dealer this morning for fuel tank replacement...Will is also going to install a DP ECU and set the TPS, sync the TBs, etc...
Last Edit: January 20, 2011, 11:08:42 AM by Gene V
Reply #3371 on:
January 20, 2011, 01:51:24 PM »
Got a bunch of Magpul goodness in the mail today.
MadDuck
The anti-
Reply #3372 on:
January 20, 2011, 10:55:44 PM »
Got a care package from Dan Kyle today. More stuff to come soon.
Speed 3 Pilot
Geezer
2014 Speed Triple R
Reply #3373 on:
January 20, 2011, 10:59:08 PM »
Hence the user name change?...
Reply #3374 on:
January 21, 2011, 03:04:32 AM »
Quote from: Gene V on January 20, 2011, 10:59:08 PM
Nah, that's more to go along with his new avatar, which is also the tattoo
(on his ass)
that Gloria talked him into getting.
224
225
226
227
421
