February 04, 2025, 02:45:28 AM *
Pages: 1 ... 377 378 [379] 380 381 ... 421   Go Down
Author Topic: What did you do today?  (Read 559323 times)
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #5670 on: July 17, 2013, 12:54:31 PM »
The computer diagnosis....didnt give them any hints....and they were not type of shop to do anything without Triumph USA's direction. Undecided Evil
Wow...and I was thinking Speed Triple for my next bike...
Life is tough, it's tougher if you're stupid...
Gettin' old ain't for wimps...
You only live once and I feel like I'm running out of time...
Flaboi796
« Reply #5671 on: July 17, 2013, 01:37:45 PM »
I believe RevTek has a good rep amongst the Japanese bike owners, don't know how much experience they have with ducactis though...I took my SF to them for a baseline dyno and they were unsure which wire to splice into to get a tach reading.
If you have a late model duc with Euro emissions you will more than likely need an ECU flash to disable the O2 sensors before a PCV will do you any good...if the O2 sensors are not disabled you will not be able to tune at lower rpms because the ECU is running in a closed loop mode...a least that's the way it worked with my bike.
Yeah I had the ECU reflashed already eliminating O2 and exhaust valve. Its running a bit rough still under 3500 RPMs and want to tune it. Ted @ Revtek said that Dynojet doesn't make a PCV for my bike, only up to 2011 model... I emailed Dynojet about this because I'm sure that it will still work on my 2013 M796.
So did you end up getting dyno somewhere else or autotune?
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #5672 on: July 17, 2013, 01:42:51 PM »
Never did dyno the bike, but had my ECU flashed by Doug Lofgren and am using a set of his flow matched injectors...
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #5673 on: July 22, 2013, 07:45:39 PM »
Reinstalled the Barracuda windscreen on the SF this afternoon...
118811
« Reply #5674 on: July 23, 2013, 10:55:45 AM »
Is that a "marketing" move FP?
Pic?
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #5675 on: July 23, 2013, 12:32:28 PM »
Pic?
No, just trying to make the bike look less aggressive...we're trying to be a bit more stealthy these days... Evil
So, how's the 675?
« Reply #5676 on: July 23, 2013, 04:53:16 PM »
and
Evil
do not go together.
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #5677 on: July 23, 2013, 05:00:19 PM »
and
do not go together.
 laughingdp laughingdp...maybe I should have said sneaky vice stealthy...
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #5678 on: July 23, 2013, 09:24:21 PM »
Pic?
« Last Edit: July 23, 2013, 09:27:06 PM by 'fighter pilot » Logged
118811
« Reply #5679 on: July 23, 2013, 10:12:00 PM »
So, how's the 675?
Looks good!!!
RE 675, sold it to the dealer......lost the left side!! Roll Eyes
Just glad to be out of it.
I am going to be patient and wait for the right bike., probably a Japanese., sport touring model.
 Dolph
MadDuck
The anti-
« Reply #5680 on: July 28, 2013, 11:29:44 AM »
Got the shorted wiring harness problem solved on Gloria's SL.  Fuse blew every time the horn was pushed. Would blow even if the horns were disconnected.  Even Boss-ski said we were up shitski after eliminating the usual suspects. Went back through the wiring harness and found a cut/mashed section in the front fender area.  Whew!  Lucked out on that one.
Got a couple emergency customer problems handled.  Pretty much got the rear suspension adjusted on the R12. Waiting on tools & parts in order to work on the front. Maybe new tires next weekend if all goes to plan.
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #5681 on: July 28, 2013, 02:57:16 PM »
 waytogo
MadDuck
The anti-
« Reply #5682 on: July 28, 2013, 03:14:37 PM »
Not so fast Bucko.  She just called from Home Depot and said the horn quit working.     bang head  popcorn   bang head
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #5683 on: July 28, 2013, 06:07:20 PM »
 boo
« Reply #5684 on: July 28, 2013, 07:04:42 PM »
What?  No horn?
Looks like it's time for a new SL.
Pages: 1 ... 377 378 [379] 380 381 ... 421   Go Up
