749-999 help
Started by truckinduc, August 17, 2008, 08:34:42 PM
truckinduc
can someone give me some 749-999 swingarm measurements?
I need to know axle diameter
I need to know pivot axle diameter
i need to know swingarm pivot inside to inside measurements.
Im also wondering if a 95 M900 wheel would come close to bolting in.
Thanks everyone.
truckinduc
ok, since that is true i can make some new axle adjuster blocks that are 17mm. Im debating on buying a swinger. My main concern is the pivot size. I know the engine case has bearings but i would have to narrow it a little.
A.duc.H.duc.
Quote from: truckinduc on August 18, 2008, 09:10:42 AM
AFAIK the modification to the engine case is pretty simple if you have any experience in fabrication. Since you're doing completely custom suspension, I really wouldn't worry about the pivot.
truckinduc
so whats AFAIK mean anyway?  Ya narrowing the case should be easy. I have to extend the frame down like on the superbikes.
People are really not going to know what my bike is, even some ducati people im sure.
A.duc.H.duc.
Quote from: truckinduc on August 18, 2008, 05:07:07 PM
AFAIK = As far as I know.
I don't think you need to extend the frame down. I believe the Superbike swingarms mount the same as an s*r swingarm.
