Which Cat eliminating Mid pipe??
Started by "One-K-Duc", August 18, 2008, 08:32:17 AM
"One-K-Duc"
I have an 07 S2R 1000 - with termis - looking to eliminate the udder.  So - which cat eliminator do you guys like for this?  I'm comparing the following:
Marving
Quat D
Spark
Main criteria:
Fitment
Quality
Looks
Thanks in advance !! [thumbsup]
07 S2R 1000 Sil/Blk - NEW mods - Spark Full Exhaust (DP ECU, open airbox), Rizoma Bars, CF Belly, CF 996 fender, SpeedyMoto belt covers, dual headlights, home tail chop, Billet - brake/clutch res covers, alternator shaft cover, oil fill plug, shock racing mini LED markers, MadDuc open clutch, Paulimoto spider-ring, removed emmissions can, CRGs, DP gel seat, removed cupcake pegs
flsurfdog
Spark.....sounds looks and fits better than DP....at least on my 06 s2r1k
06 s2r1000, Apex Clip-ons, Lowered headlight and gauges, HID high/low, Wasen Design front signals, reflectors removed, Mag Performance clutch cover, Rizoma star pressure plate, open airbox, Spark midpipe, Leo Ti slip-on, tail chop and frame plug blinkers
TJR178
Quote from: flsurfdog on August 18, 2008, 09:14:12 AM
+1.  I like my spark.
I have Spark on my 800 - more or the less the same deal as on a 1k, I guess.
It was the first time my dealer's sceptical head mechanic had put on anything other than DP AND concluded it was a better fit and better sound.
Personally I like the routing of these much better than the DP pipes.
My biggest surprise was the sound improvement. People had said I shouldn't expect too much - they were WRONG [moto]
"One-K-Duc"
Thanks for the input one and all!! That pic really helps me as well!!
PS - I'm thinking of wrapping with black heat wrap or having the whole system coated in jet hot etc...  I think black pipes from head to tail will look awesom as I have the silver and blakc s2r
thanks again!!
Qfactor
I have a spark "cat eliminator" in the for sale section...
Q
flsurfdog
Quote from: stopintime on August 18, 2008, 01:46:34 PM
+1   WAY better sound.  much lower, and a little louder....i think it shows their cross over is functional and the tiny little pipe between the DP headers are lame
ICON
Who sells spark mid-pipes?
Are they 50mm?
O2?
Quote from: ICON on August 21, 2008, 10:26:25 AM
Are they 50mm?
O2?
I thought DesmoWorld in Germany was the "only" vendor, but suddenly Jeff at MonsterParts had it.
50mm? Don't know, sorry.
O2 - yes and you can see how clever it has been positioned in my picture above. If you need to use the sensor there might be a need to reroute or replace cable with a longer one (I think some had to do it that way?) I have the DP ECU and therefore no O2 sensor, so in my picture there is just a "bolt" in there.
Dream
Quote from: Qfactor on August 18, 2008, 06:58:25 PM
Q
Will it fit S2R 800?
