February 11, 2025, 09:29:00 PM *
Author Topic: Custom CF locally?  (Read 1713 times)
DucNrun
« on: August 18, 2008, 08:23:16 AM »
So here's my vision:  I'd like to have some CF cans shaped just like the stockers on my S4RS.  To my knowledge, nobody makes them, so I was wondering if I could have them made, and if someone locally manufactures CF so that I can get the sleeves done for my cans.  With these hypothetical CF sleeves, I could then cut the end caps out of my stock setup and make up a nice cored set of cans and retain the cool styling of the stockers with the added performance and looks of free flowing CF cans.  Or would it be cheaper to get a set of Arrows?  BTW, assume the addition of a midpipe.
duckwrench13
This thing sounds broken...
« Reply #1 on: August 18, 2008, 10:33:15 AM »
When you look at all the associated costs, and time involved, buying an after-market set of pipes... Arrows, Remus, etc... is the way to go.  and gutting the OEM pipes is not as clean and easy as you'd think.
A ready made, known to work, set of pipes is the way to go. Plug 'n play, and back on the road!
Of all the things I've lost, I miss my mind the most.
Gettin' blow'd up sucks!
Combat Veteran, Operation Enduring Freedom, Afghanistan 2006-2007
Vindingo
02' 620 Dirty
« Reply #2 on: August 18, 2008, 01:01:25 PM »
If you just want the CF looks, why not just wrap the stockers with a layer of CF and have it clear coated.  You could order a sheet of  it online and just get some resin from home depot.  You could probably pick up a cheap used set to practice on.
TCK!
I'm A Hot Chick
Oh really?
« Reply #3 on: August 18, 2008, 01:16:32 PM »
CF stickers [/thread]
DucNrun
« Reply #4 on: August 18, 2008, 01:31:33 PM »
I don't want to pose, I'd rather have the real deal.  Basically, I want a high performance muffler (e.g. Arrow, Termi, etc) with the looks of the stock cans.  In a perfect world, I wouldn't need to go through the hassle of coring a set of cans so much as just taking the end caps from them along with some exhaust packing and a couple of perforated tubes in order to make a set of neat and unique mufflers.  I just thought I'd explore the option and see what resources are available.
DarkStaR
« Reply #5 on: August 20, 2008, 04:30:11 PM »
Make them yourself:
http://www.pjengineering.co.uk/products.asp?cat=8&pg=4
« Last Edit: August 20, 2008, 04:31:53 PM by DarkStaR » Logged
hypurone
« Reply #6 on: August 21, 2008, 06:25:23 AM »
Something tells me there would be a heat problem in this configuration and would lead to premature discoloring or failure of the carbon. When a can is desgined with carbon in mind, there are thermal precautions made. Either a barrier or special packing to minimize the heat transfer to the carbon itself.
Just a thought... coffee
DucNrun
« Reply #7 on: August 21, 2008, 06:44:20 AM »
I hadn't thought about that, but good point--especially given how the S4RS cans are shaped, I could see one side of the cans in particular getting excessive heat exposure.  If only a good second-hand set of CF Arrows would turn up... bang head
