January 31, 2025, 10:58:29 AM
CAM
windscreen customizations
Topic: windscreen customizations (Read 4296 times)
Duc and Cover
2006 S2R1000 - Silver, Black, and Effin Fast!
May 08, 2008, 08:15:58 AM »
My new DucDual headlights leave a lot of exposed wires (since I removed my front fairing), so I was thinking about covering that area back up. But I hate the look of the stock windscreen coming up over the gauge cluster. So it occurred to me I could use my original front-fairing, but then carve off most of the section for the windscreen. Has anyone chopped up their front fairing like this before (or heard of anyone else doing it)? Or does someone already make a mini-fairing like this?
Here is my artist's rendering of what I am trying to accomplish:
...CRG bar-ends, DIY tail chop, open clutch cover, open timing belt cover, stainless clutch springs w/black caps, Bitubo top-mount steering damper, 14-t front sprocket, integrated LED smoked tail light, clear front mini signals, full Termi exhaust, DP open airbox, DP ECU, suspension tuned by DucPond Racing, flipped handlebars, titanium Rizoma reservoirs, DIY chopped bikini fairing, DucDual headlights w/halos, mini CF rear chain guard, pro-grips, misplaced emissions canister...
Duc and Cover
Re: windscreen customizations
May 08, 2008, 10:42:10 AM »
So I did some research and it looks like there are lots of smaller windscreens out there called bikini fairings. But none quite as small as what I'm going for. I think I'll take out my hacksaw tonight...
zooom
May 08, 2008, 11:44:37 AM »
http://www.ducati.com/shop/product.jsp?catid=cat1060106&prodid=prod980102
looks like it might do exactly what you are getting at having done...
2010 KTM 990 SM-T
Duc and Cover
May 08, 2008, 12:52:12 PM »
Quote from: zooom on May 08, 2008, 11:44:37 AM
Too late, already finished...now I've got a color-matched bikini fairing. Tools: Hacksaw, file (rasp?), epoxy. Time: 1 hour
I'll post a pic of the bike with this new fairing and the DucDual headlight later...
jetpuff716
'06 S2R 800 (Black & Tang); '06 PS1000
May 08, 2008, 02:31:09 PM »
damn dude... the hacksaw has got to be your favorite tool in the box. you should change your screen name to "hacksaw."
Duc and Cover
May 08, 2008, 02:48:50 PM »
Is that from your spank-bank?
Duc and Cover
May 08, 2008, 03:42:37 PM »
Beeeeee-yootiful
Duc and Cover
May 08, 2008, 04:37:19 PM »
Honestly, I'd probably do the same thing if I had a Triumph. If there's one thing I learned from growing up around Harleys, it's that stock anything is bad. And arbitrarily spending money to change things for no other reason than to not be stock is always good. Even when I hear how ridiculous it sounds when I say it like that, I still can't help but think of my next mod...
