Removing the mufflers, possible with just hand tools?
Started by corpthug, August 20, 2008, 12:44:49 PM
corpthug
and if so, which tools are needed?  Apologies for such the ignorant question but as I've never worked on cars/bikes before I have no clue what's needed.  The first "mechanical" thing I've done thusfar on my bike is installing Pazzo levers so that should give some indication of how new I am to this.  As always, helpful responses greatly appreciated.
2006 S2R-Dark
mods.. well they will come..
Hank
'00 Monster 750 Dark
Current mods: K&N and removal of the intake silencers,  AFAM 14 tooth front sprocket.  Termignoni high mounts <---Best mod yet!, Evoluzione slave cylinder,
NEW: removed dinky plastic covers and emissions canister for moar n00dity!
"I like my women the way I like my roads; with plenty of curves!"
corpthug
2006 S2R-Dark
doesnt matter what bike you have. More than 90% of the bike is put together with hand tools. So yes you can take them of with a a hex set and some sockets.
corpthug
Quote from: He Man on August 20, 2008, 01:14:40 PM
Great.  Picking up a set later tonight.  Is there anything I should look out for when trying to remove the mufflers from the udders or is it pretty straight forward?  (well considering my inexperience in mechanics)
2006 S2R-Dark
minnesotamonster
2004 S4R
1998 Honda F3 (Track)
2001 M600 (Now the Wife's)
RBX QB
Just loosen everything that looks like an allen connector from the udder back. If memory serves, there are 5 (I have the same bike). There are 2 pipe clamps at the udder, 1 on each pipe. There are 2 more pipe clamps at the connection of the mufflers. There is 1 more attaching the muffler bracket to the frame. You COULD remove the mufflers from the bracket, but it's not necessary.
As for reassembly (if you so choose), just remember to fit all the pieces back together loose before you tighten all the bolts for the final time. There may be some wiggling required to get the pipes to seat to the udder and mufflers correctly.
corpthug
As a side question, has anyone ever just taken off the mufflers but left the pipes leading to the udder on??  So there would be two pipes sticking out near the rear pegs, rather than having two openings on the udder.  I don't think I've seen anything like that on these forums.
2006 S2R-Dark
people have done it, but it looks ugly as make the beast with two backs imho.
brimo
Careful with overtightening the clamps , the bolts will jam and you'll then have to cut them off (personal experience here), use some antiseize on the bolts before you reinstall too.
+ 1 on the metric hex keys too, the imperial ones will fit but will strip out the heads, also spend a little more and get good quality hex keys, crap ones will also damage your bolts, and possibly your fingers too when they snap.
From a story by RAT900
teddy037.2
Quote from: brimo on August 20, 2008, 03:55:02 PM
which means they don't fit  ;)
always use the right tools for the job  [thumbsup]
If you want cheap but well built American Metric tools, i like craftsman or Husky. (atleast i hope craftsmans are made in the US, im not sure) Husky has a full hex set up to 11mm. Good for your oil drain plugs and rearset bolts, incase they get loose.
corpthug
All, thanks for all the responses!  I'm a pretty impatient person so after work I headed to Home Depot and picked me up a nice Husky tool set.  Well, I never realized how easy it would be to take the mufflers off but here she is:
But after riding around the block with this setup, I realized this is way too LOUD.  Def a popo attraction.  So I put on the connector pipes so even if it looks uglier, here she is:
After riding around with this setup for the wknd I'm prob gonna decide for sure which after market exhaust I want to put on it.  As of now I'm leaning towards the Quat-D Ex-Box.  The minimalist rear end is looking pretty good to me right now.
Again, thanks for the tips!
2006 S2R-Dark
herm
i recommend the x-box. ran with just the udder for a long time, but it was too loud.
the x-box is the perfect medium between stock and too loud
No more Monster.
RBX QB
Deja vu... went through the same process.
1) Remove s pipes and mufflers = Too loud
2) Reinstall s pipes = Still kinda loud... not refined enough
3) Reinstall mufflers = Wait for ExBox money
