January 06, 2025, 02:13:04 AM *
Pages: 1 [2]   Go Down
Author Topic: Need steering damper advice  (Read 5209 times)
DucSteve
Hey Yo
« Reply #15 on: August 25, 2008, 03:52:21 PM »
the M4 is pretty badass... not sure if its really worth the extra $$$ but sure looks tite
Ducnial
« Reply #16 on: August 25, 2008, 06:34:15 PM »
Its a steering damper not a piece of jewlery and to be honest your the only one thats really going to notice.  Cool   if your riding style is less agressive and you dont plan on taking it to the track you'll probably never need or miss one.  All are pretty good and I'd challenge most to tell the difference between any when properly adjusted. I bought an Arrow Ti Comp top mount $365 and have been very happy, mounted in 20 mins.  Does a good job of calming things down,  especially on the track comming out of turns hard on gas, no more shivering.  On the road it takes away any rear end squiggle that sometime happens with poor steering inputs  bang head because it forces more counter steering over head-tube steering and thats a good thing. waytogo   Personally I'd recomend a top mount.  Not enough room under the triple for undermount and the side moults just look fragile and finincky. If you do go with a top mount expect to disconnect it whenever you want to lift the tank.  I'm not sure about  the others but the top mount Arrow, Ohlins and probably the Matris wont clear the gas tank, not sure about the DP or Bitubo?
Get a good one and you cant go wrong.
jesse370
« Reply #17 on: August 25, 2008, 08:12:19 PM »
I had a DP damper.....It failed in under a year, every seal failed. BUT with that being said if you have a dealer install it you get a 2 year warranty.
It was a great part till it failed, so I can't complain as far as that goes.
White S4Rs | Ducati Performance Chip | Termi's | Hyperpro side mount damper | Motowheels MW-7000 Slipper | Billet Clutch Cover |  Speedymoto Ti Spring Caps | Speedymoto Stainless Springs | STM Frame Plugs | Ducati Performance Seat | CRG Roll-A-Clicks
CairnsDuc
« Reply #18 on: August 25, 2008, 08:29:27 PM »
The top mounts look good, but how does it go if you have risers fitted for your handle bars?
Ducnial
« Reply #19 on: August 26, 2008, 06:14:51 PM »
You'd need to raise the height of the bracket that mounts to the key/emobilizer. The Arrow came with spacers and longer bolts.  Making new spacers would be easy. The question would be if the longer bolts are available.
c_rex
Quick! Into the transmogrifier!
« Reply #20 on: August 26, 2008, 07:12:04 PM »
Speedymoto bolts run an extra 20mm to accomodate their own risers.  You can always get longer bolts and cut them down too.  Places like Tacoma Screw should be able to help you with the approximate length as long as you have the proper thread and pitch.
ghosthound
« Reply #21 on: August 26, 2008, 09:42:28 PM »
Nay Nay! The Matris M4 is the shiznit! The only one I've seen with a TiN coated piston rod!!  Shocked
The unit is gas pressurized as well and has taken everything I could throw at it without a quiver, including wet cattle guards!! No pun intended...
http://i239.photobucket.com/albums/ff38/hypurone/Monster%20S4RS/P1010047.jpg
where did you get that top mount from?
hypurone
« Reply #22 on: August 27, 2008, 06:25:51 AM »
Dept of Suspension. but I hear that Jason stopped being the US importer. It seems Matris was becoming something of a PITA to him and he really didn't have the time to deal with their ever increasing demands. At this point I'm not sure of who a US importer is.  Tongue You may be able to go direct?
I called Jason and confirmed that he is no longer dealing with them. But he said there is another company handling the dampers. He said to email Matris at info@matrisdampers.com. I am gonna send something to that email and see what response I get.
Splinter Cell
« Reply #23 on: August 28, 2008, 09:16:33 AM »
Because the Arrow bottom mounting bracket have a perfect fit with the Ohlins Damper.  I'll post up part numbers tonight.
Please do not forget to post the part numbers
Thanks!!!!!!!!
06 DUCATI Multistrada
08 DUCATI Monster S4RS TRI
arai_speed
« Reply #24 on: August 28, 2008, 10:14:09 AM »
Thanks!!!!!!!!
I posted them on the "Review" thread...but here they are:
Arrow Part #: 11052DA
Ohlins: SD 163 Damper
I'll need to post individual part numbers for the Ohlins kit as an SD 163 search just returns the entire kit (which you don't need).
ghosthound
« Reply #25 on: August 30, 2008, 10:52:13 PM »
man, i was hoping you orderd it from someone else.  Ive tried contacting matris before and they never responded...
hypurone
« Reply #26 on: September 02, 2008, 05:17:00 AM »
Yup. so far, no response to my email.  vomit
ghosthound
« Reply #27 on: September 04, 2008, 01:01:43 PM »
ok, got a response... 758 for the m4 with the top mount brackets!!  Shocked Shocked
hypurone
« Reply #28 on: September 05, 2008, 05:22:12 AM »
Check out the other thread I started in A&M. There is some new contact info there and a rumor that PJ's Parts is picking up Matris.
http://ducatimonsterforum.org/index.php?topic=10657.0
ICON
« Reply #29 on: September 05, 2008, 08:10:04 AM »
It is a M3, Matris Damper I took off my 620. I drilled some holes on the stock bracket and mounted it right into it. It sit's lower than other dampers and clears the tank. I have it set to #8. I think if your Suspension is setup correct you don't need to go super hard with your Damper.
I bought it directly from Matris. So far this Damper rocks!
 waytogo
Pages: 1 [2]   Go Up
