January 06, 2025, 02:08:02 AM
Please Help
Need steering damper advice
Topic: Need steering damper advice (Read 5208 times)
Joe
August 24, 2008, 05:31:12 PM »
I'm looking for a top mount damper for an '07 S4Rs.
What do you look for in a quality damper?
Is gas or oil filled a better choice? Does temperature affect one more than the other?
What brands do you recommend?
Thanks
Joe
crazy bike girl
aka msincredible
Re: Need steering damper advice
August 24, 2008, 08:22:16 PM »
You might want to check out my
review thread
photo FAQ
BellissiMoto
August 24, 2008, 08:32:11 PM »
Quote from: msincredible on August 24, 2008, 08:22:16 PM
review thread
+1
I have had 5 monsters, and can identify with many of the posters in that thread.
You will note some similarities too;
Any damper is a huge improvement over no damper at all, and The more adjustable ones seem to be ranked better.
Personally my favorites are Bitubo, and Matris, but the HyperPro ones are very nice as well (just not Italian).
I do not however, find the Ohlins to be fit to ride upon my bike.
uclabiker06
"The time you enjoy wasting isn't wasted"
August 24, 2008, 08:41:36 PM »
For top mount dampers your choices are
1)Bitubo (my favorite)
2)Ducati Performance
3)Arrow
4)Matris
5)Scotts
I don't know if all of them will fit but I don't think there are any other options for top mounts.
2006 S2R
2009 Smart
c_rex
Quick! Into the transmogrifier!
August 24, 2008, 08:46:15 PM »
I went with a DP on my S4RS and am very happy. Price being a motivator I think you'll be happy with anything that fits properly and doesn't cause any headaches on install. fwiw- some lend themselves to being rebuilt better than others being oil/seals rather than gas charged. they do help quite a bit with the bumps as well as downshift hop on the RS so anything will be grand.
arai_speed
August 24, 2008, 08:52:29 PM »
Quote from: uclabiker06 on August 24, 2008, 08:41:36 PM
3)Arrow
4)Matris
5)Scotts
6) Ohlins Top mout (arrow brackets, Ohlins damper)
On my bike now:
uclabiker06
August 25, 2008, 07:36:05 AM »
Quote
Ok, but why Arrow brackets.?
2006 S2R
2009 Smart
"One-K-Duc"
August 25, 2008, 08:18:05 AM »
Any recommendations for a side/frame moun versus top??
07 S2R 1000 Sil/Blk - NEW mods - Spark Full Exhaust (DP ECU, open airbox), Rizoma Bars, CF Belly, CF 996 fender, SpeedyMoto belt covers, dual headlights, home tail chop, Billet - brake/clutch res covers, alternator shaft cover, oil fill plug, shock racing mini LED markers, MadDuc open clutch, Paulimoto spider-ring, removed emmissions can, CRGs, DP gel seat, removed cupcake pegs
arai_speed
August 25, 2008, 09:10:41 AM »
Quote from: uclabiker06 on August 25, 2008, 07:36:05 AM
Because the Arrow bottom mounting bracket have a perfect fit with the Ohlins Damper. I'll post up part numbers tonight.
DucSteve
Hey Yo
August 25, 2008, 10:18:47 AM »
and where would one go to buy these dampers?
geoffduc
18 till i die
August 25, 2008, 10:30:02 AM »
i've gone down the same route as c-rex and found the fit and quality 1st class of the DP steering damper but be very carefull when you lift the fuel tank,just my 2pence
2015 scrambler FT
2009 monster 1100s
uclabiker06
August 25, 2008, 11:29:17 AM »
Quote
They both do the same thing. Its just a matter of aesthetics. I think the side mount ones are a tad cheaper generally speaking.
Quote
Just check out some of the links under DMF Sponsors. Desmoworks sells the Bitubo and Arrow I think.
2006 S2R
2009 Smart
Joe
August 25, 2008, 12:42:27 PM »
It sounds like the consensus is to defiantly get one, but which one to get is more personal preference.
I was hoping that there was one that stood out above the rest, but it sounds like most people are happy with whatever they use.
I found the Matris M3 for$499.99 and the Bitubo for $514.00.
I’ll probably go with one of these.
Thanks
Joe
uclabiker06
August 25, 2008, 01:11:17 PM »
I think that everyone would agree that for those prices you should definitely get the Bitubo. Its way more blingability than the Matris.
2006 S2R
2009 Smart
hypurone
Reply #14 on:
August 25, 2008, 02:38:38 PM »
Quote from: uclabiker06 on August 25, 2008, 01:11:17 PM
Nay Nay! The Matris M4 is the shiznit! The only one I've seen with a TiN coated piston rod!!
The unit is gas pressurized as well and has taken everything I could throw at it without a quiver, including wet cattle guards!! No pun intended...
http://i239.photobucket.com/albums/ff38/hypurone/Monster%20S4RS/P1010047.jpg
