seat swap
Started by Butcher, August 25, 2008, 11:15:12 AM
Butcher
Looking at doing some swapping on my bike.
I have a 96 M900.
I can source a fuel tank from a 2001 M600 dark (carb'd).
If I understand it correctly, it will work, but I will need a 00- > up seat.
Will a seat from a 2007 S4r work?
In other words, is the hardware and the tank "cut outs" for the seat the same on a 2001 M* and a 2007 S*r?
According to the Corbin site, there is one shape seat for 93-99 and another from 00-05.  They don't mention anything post-2005.
Thanks,
Bob
uclabiker06
Since you have the new gas tank it should work.  Maybe call Corbin and ask them to be sure.  I don't think there is a difference from '05 to current seats.  I had an older seat on my '06 bike. The only problem I had was that I had to press really hard for it to click into the latch and sometimes it would come loose while I was riding.  Then I added a washer to each side to bring the locking mechanism a tad higher and the problem was easily solved.
2006 S2R
2009 Smart
Rameses
The latch mechanism on your 96 900 uses a hoop on the seat that presses down into the latch on the bike.  Right?
The newer bikes have a notched pin that sticks down off the seat and pushes into a latch on the bike.
I don't have any experience with older stock seats, just Corbin and Sargents.  The aftermarket seats have a removable latch hoop on the seat that can be swapped onto a newer seat to make it work.
Check your seat and see if its possible to take off the hoop.
I'm not sure if a newer stock seat allows the latch pin to be taken off and swapped to a hoop, but the aftermarket seats definitely do.
uclabiker06
You can always go to the dealership and ask them to take a seat off one of their bike and put it on yours so you can see if you like it.  If you don't like it then don't buy it from them.
2006 S2R
2009 Smart
