Yet more steering questions...
Started by uclabiker06, August 25, 2008, 12:09:14 PM
uclabiker06
Okay, so I managed to remove the triple clamps for powder coating. I assume the shaft is not supposed to be powder coated along with the bottom triple. So do I remove the shaft along with the bearings from the bottom triple?  Doesn't look like it is supposed to be removed.  Any advice appreciated.
2006 S2R
2009 Smart
A.duc.H.duc.
Quote from: uclabiker06 on August 25, 2008, 12:09:14 PM
Remove the bearing from the shaft, then mask of the shaft.
Plan on replacing your bearings, as you will most likely trash the current bearing getting it off.
uclabiker06
#2
Okay thanks.  I was thinking of replacing the bearings with tapered Speedymoto bearings but I don't know if it will be worth the hassle to replace the outer rings on the steering tube.   I don't really think the tapered bearings will offer noticeable improvement from the OEM ball ones.  Since I don't have a bearing puller I think I am going to give it to my local shop to remove and seat on the new ones properly onto the shaft after powder coated.  That way I can just slide it back in and not mess with replacement of the outer races.  Kind of a wussy route but I just didn't find any real advantages to tapered bearings and I don't want to risk ruining the seats.
2006 S2R
2009 Smart
