February 08, 2025, 01:54:05 AM *
Author Topic: front fork seal problem  (Read 2189 times)
bizza
« on: August 25, 2008, 12:55:09 PM »
Hey, so I've had my bike ('94 m600) for a few weeks now, and on sunday I noticed the seals were leaking. I called the previous owner's mechanic yesterday to book it in for the seals to be replaced, and he tells me that the part of the forks that the seals rub against is corroded on my bike, and so just getting the seals replaced is only gonna be a short-term fix. Apparently the forks need to be re-chromed.
Just wondering if anyone here knows roughly how much it's going to cost me. I asked the mechanic and he said he would get back to me because they were busy and he had to check.
Dockstrada
« Reply #1 on: August 25, 2008, 01:15:34 PM »
Hey Bizza I have a set of forks that you can have they are scratched on the outside but the chrome leg is mint, send me you address I can post them.
« Last Edit: August 25, 2008, 01:17:11 PM by Dockstrada » Logged
If I wasn't who i was, I wouldn't be who I am !
bizza
« Reply #2 on: August 25, 2008, 01:26:13 PM »
 Shocked mate that's a really generous offer! I live in townsville, qld. Depending on what the rechrome will cost and if you wanted to send them up, I could deposit some money in your acc to cover the cost + like $100 for your trouble. I would just need to know how much the rechrome is gonna cost first is all.
Dockstrada
« Reply #3 on: August 25, 2008, 01:40:28 PM »
No need TNT will be about peanuts, buy some bling for your monster instead,I cant stand seeing it like that  laughingdp waytogo
Send me your address and which side fork is it, sitting on the bike right or left Huh?
PS: I guess we need to know if the will fit first, get me the dia and the length of the fork. for your referance they came from an 02 mod .
« Last Edit: August 25, 2008, 01:44:53 PM by Dockstrada » Logged
bizza
« Reply #4 on: August 25, 2008, 02:10:33 PM »
Quote
laughingdp
ummm, it's the right hand side when sitting on the bike. Not sure on the length and diam, but I just got off the phone from our local ducati dealer and he seems to think that 94 and 02 monster forks would be interchangeable. PM sent, thanks for your help!  Smiley
Edit: diameter is 40mm, dunno about the length
« Last Edit: August 25, 2008, 03:17:14 PM by bizza » Logged
loony888
"I WAS GOING HOW FAST, OFFICER?"
« Reply #5 on: August 25, 2008, 11:23:38 PM »
so, you ring this mechanic and he tells you the chrome slider is chipped/pitted/corroded or whatever? if he knew about it without seeing it did he do the roadworthy? if so, i'd be getting a little upset as oil leaks are a fail on a roadworthy.
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
bizza
« Reply #6 on: August 25, 2008, 11:49:20 PM »
Perhaps when they last replaced the seal (for the roadworthy or whatever) they thought the corrosion wasn't that bad and the seal would hold out longer. I'm not too sure, I'm just focusing on gettin it fixed atm.
dragonworld.
I can make like a tripod with my.....
« Reply #7 on: August 26, 2008, 12:11:35 AM »
paul.
As are damaged suspension components??? He obviously had senn it and knew about it?? Roll Eyes Huh?
« Reply #8 on: September 03, 2008, 10:44:04 PM »
You'll need to work out which forks you've got. Some of them (like the non-adjustable Marzochi's on my '99 M750) aren't able to be rechromed (well, not easily, apparently the fork bottoms are pressed in and they're very difficult to dissassemble and reassemble compared to "normal" forks).
big
Dockstrada
« Reply #9 on: September 03, 2008, 11:21:22 PM »
So my offer still stands let me know if you want me to send the fork waytogo
brad black
« Reply #10 on: September 04, 2008, 04:13:14 AM »
the early ones have 40mm caliper screw spacing, '99 or '00 onwards all of the range had gone to 65mm i think.  the later ones will be 43mm diameter too and have some sort of cartridge inside if they're marzocchi.  all showas have cartridges.
the 600m have 40mm marzocchi that are just crap, and the chrome does wear off and rust as part of use.  we've had RAD in maroochydore (maybe) do a few sets of various things for us, and i think they've done the non do-able marzocchi before for us.  they end up a touch shorter i think, as they have to machine the old retaining rolled edge off and then redo it later.
or get some 40mm caliper spacing forks from something else.  the adjustable marzocchis seems to be better chrome wise, or the showa non adjustables from a 900m/early 750ss or the adjustable showas from a 900ss will go straight in and showa chrome is almost perfect.  i've just put revalved and resprung 41mm non adjustable showas in my 600/750 and they're very nice.  i was thinking of machining up a plug to weld in the bottom of the original 40mm marzocchis tubes on mine and then fitting some cartridges from the showas, etc, but i found a rh showa non adj on ebay to match the new lh leg i had so ran with them.
Brad The Bike Boy
http://www.bikeboy.org
