Heavy Modded 696 at Indy
Started by Spidey, September 12, 2008, 10:14:38 PM
Howley
Who was it that said a 4v wouldn't fit in the 696 frame? Wheel hitting the radiator etc...
Capo
Quote from: Howley on September 30, 2008, 05:39:39 PM
Obviously someone who had never tried to do it.
Capo de tuti capi
Quote from: Capo on October 01, 2008, 04:26:50 AM
Just because it is not hitting when parked doesn't mean it won't hit when riding it.  It looks really close in the side view pics.
DW
Quote from: mitt on October 01, 2008, 12:59:21 PM
Well, when I spoke to the guy at Indy, he did state it was a heavily modified 696 frame.  Where there is a will, there is a way.
Besides, that just makes it more like a 1098 R, which got held out of masterbike this year because changing to a different tire brand caused the front to hit the radiator.
Howley
Pretty sure he wouldn't go to all that trouble if he couldn't even ride it.
Rameses
I remember thinking the same thing while I was standing there looking at it.
It really did look like it was going to make contact when the forks compress.
Quote from: Howley on October 02, 2008, 12:01:46 AM
Others have...
It is hard to know exactly if it will touch with all the flex and bounce and compression that a front end goes through.
There have been more than several threads over the years on Monster forums about this problem when folks are doing engine swaps / radiator locations / custom frames / etc.
Looked at the pics a bit closer....
IMO, the front wheel will hit the rad.
Statler
hell the first batch of S4RSs on our shore had the rad clearance issue right out of the crate.
This pic looks like contact waiting to happen.  Regardless it is a great looking bike, with a lot of nice work, and will be very cool when it is finished.
Evil_Ductator
ehh, just go MotoGP style and put smaller front wheel on it :)
Or move the radiator undertail, do an under bike exhaust and a different cowl to vent the heat
;D
MotoCreations
If the tire might hit the radiator -- just build a new radiator or modify the existing one.  Pretty easy to do.
To mount beneath the seat?  it would be a nightmare to put the radiator there-- not enough air volume and too close to the exhaust besides the waterline routing headache that would occur -- you'd have to run the water lines external of the frame which would be fugly at best.
ARC pulled it off ;D (which is where I got the idea)
Not sure why the image won't load, so here's a link
http://img183.imageshack.us/my.php?image=srostupyp0.jpg
DucHead
Quote from: MotoCreations on October 02, 2008, 03:00:38 PM
...To mount beneath the seat?  it would be a nightmare to put the radiator there-- not enough air volume and too close to the exhaust besides the waterline routing headache that would occur -- you'd have to run the water lines external of the frame which would be fugly at best.
Didn't Benelli do this?
