JTMOTO
« on: October 09, 2008, 02:12:27 PM » |
This is probably a stupid question, but does it matter what side of the bike I mount an Ohlins damper on? Anyone have an opinion on what side makes more sense? Thanks J
« Reply #1 on: October 09, 2008, 02:13:56 PM » |
If it is an adjustable damper mount it on the left so you can adjust and use the throttle at the same time.
"Once you accept that a child on the autistic spectrum experiences the world in a completely different way than you, you will be open to understand how that perspective is even more amazing than yours." To realize the value of nine months: Ask a mother who gave birth to a stillborn. "Don't piss off old people The older we get, the less 'Life in Prison' is a deterrent.”
« Reply #2 on: October 09, 2008, 02:23:38 PM » |
Why would you adjust and ride at the same time?
ducducgooseme
Same ole DesmoDevil, in a more gentle package
« Reply #3 on: October 09, 2008, 02:30:40 PM » |
because its a simple turn of the knob... yeah, left side
If you love your bike, set it free. If it comes back to you, you've probably high-sided.
« Reply #4 on: October 09, 2008, 02:34:05 PM » |
Why not?
OverCaffeinated
« Reply #5 on: October 09, 2008, 02:48:53 PM » |
Yup... Left side. I adjust while riding here and there.
« Reply #6 on: October 09, 2008, 03:21:44 PM » |
Why not?
Cause your mind should be focused on riding and not fiddling with a knob? Cause you can just stop and adjust it when your trying to not get ran over? I have a hard enough time checking my mileage without having some dude completely cut me off in that split second.
« Reply #7 on: October 09, 2008, 03:26:37 PM » |
well maybe if you were a track rider than you could adjust based on sections of the track??? i dont know. i dont have adjustable. nor do i track ride. well guess i shouldnt have really said anything, cause i got nothing... do what's comfortable for you. mock it up and try it both sides..
« Reply #8 on: October 09, 2008, 03:32:54 PM » |
Then you shouldn't adjust anything while you ride. Not everyone rides in your conditions. Some of us can ride for miles without ever seeing a car. Every side mounted damper I've ever seen was mounted on the left side. When installed as intended the knob is within reach of the rider.
squidwood
« Reply #9 on: October 09, 2008, 04:50:24 PM » |
On the bike my knob is in reach of the wife............
« Reply #10 on: October 09, 2008, 07:38:31 PM » |
You can mount it on either side, but on the left is convention for just the reason ducpainter said. You may want to turn it down in city/town conditions and up for other conditions. Adjusting a side mounted or top triple mounted damper is as easy if not easier than adjusting a mirror.
Scooter-Trash
« Reply #11 on: October 09, 2008, 10:41:46 PM » |
Uh, I'm going to suggest mounting it on the outside.
Seriously, left side seems pretty standard. And yeah, you can and do end up fiddling with it when you ride.
Dannog
« Reply #12 on: October 10, 2008, 03:20:47 AM » |
Every photo of Monsters with Ohlins remote dampers I've seen has it mounted on the RHS just above the clutch pressure plates.
« Reply #13 on: October 10, 2008, 03:28:01 AM » |
Every photo of Monsters with Ohlins remote dampers I've seen has it mounted on the RHS just above the clutch pressure plates. Pretty sure the OP is talking about a steering damper... not the remote reservoir for a suspension damper.
Dannog
« Reply #14 on: October 10, 2008, 03:53:42 AM » |
certainly make more sense then.
