I have a weight problem.
Started by TAftonomos, December 04, 2008, 03:55:31 PM
CowboyBeebop
Quote from: TAftonomos on December 05, 2008, 10:26:29 AM
Check this out:
Li-Iron battery.   Under 2lbs :)  By far the cheapest weight savings I've done too..
Will be for sale shortly, I need a website heh.
Is that big one the stock battery?
TAftonomos
Yes.  Thats the stocker, sitting next to the replacement.  They make a smalled speedcell that is sub 1lbs, but it's not recommended for a street bike running lights.
It's crazy, but that kind of technology will be in the hybrid cars coming out in the next few years (if they are released/built) in the US.
CowboyBeebop
Quote from: TAftonomos on December 05, 2008, 05:00:17 PM
These batteries deserver their own thread!
TAftonomos
As soon as I get my dealer portion setup, I'll start one :)  [thumbsup] [wine]
CowboyBeebop
Quote from: TAftonomos on December 05, 2008, 05:23:28 PM
If you can give me a product that:
1. Reliably starts my daily-driver 900FI without additional care and feeding (tender charging whenever parked, etc) in regular temps (45 - 100 F)
2. Is waterproof
3. Weighs 3-4 pounds or less
I'm buying one.
MonsterMan1036
TA,
Will you PM me the info, I'll probably buy 2-3 of the midsized ones.
Alex Ortner 1036CS
1036 Foggy Monster (sold)
Commonwealth 848 track bike
1199 Tri
mojo
Quote from: Triple J on December 05, 2008, 10:51:33 AM
Very nice!!! How does it perform in cold weather, or when the bike doesn't feel like starting and needs to turn over a few times? Can it sit on a trickle charger, or does it need to, like a normal battery? Any idea on approx. cost?
Li-ion batteries are less affected by temperature, and do not lose a charge while in storage like other batteries.  But, you need a different charger for them, and they have a tendancy to explode if not handled properly.
Some people are like slinky's.  They serve absolutely no purpose, but they always bring a smile to your face when you push them down the stairs.
Ashmon
These batteries are very interesting. From what I have read from all of their details, the Batteries are not Lithium-Ion, but rather Lithium-Ferrous. These are not volatile at all, and are plug in play with normal chargers, and if you get the superbike pack then it should be plug in play with your ducati. The price of the superbike pack looks to be around $250
CowboyBeebop
Quote from: mojo on December 06, 2008, 08:07:21 AM
From the Speedzilla thread, it looks like these batteries aren't li-ion.
mojo
Sorry, didn't read the speedzilla thread.  Taftonomus stated that they were Li-ion when they are A123 cells.
CowboyBeebop
Quote from: mojo on December 06, 2008, 01:54:54 PM
I just read it again (I wasn't sure).  They are lithium-ferrous.
Check this out:
Original post, highlight added. Iron it is.
TAftonomos
Quote from: Obsessed? on December 06, 2008, 05:25:20 PM
You are the winner :D [clap] [drink] and  [bacon]...I love the food emocons...
In any case, EVERY battery needs care and feeding IMHO, and I'm not sure I'd use something like this without, nor would I recommend using it without a tender on it at night.
PM sent.
TAftonomos
Thats T Aftonomos cheif :D
TAftonomos
#29
More Ti just arrived  ;D
Front rotor bolts (not pictured), rear rotor bolts, rear caliper mounting bolts/washers, caliper bolts (ones that join the halfs together), Sprocket bolts for the quick change.
All adds up to 1.2lbs of rotating mass shaved/gone.  Just to match I grabbed the 3 bolts that hold the brake line onto the swingarm.
The dang wave rotor for the rear (that is 12 ounces lighter than stock - 3/4 lb) is on backorder for 2-3 weeks.  Once that gets here, I'll install it all.  The actual weight drop overall isn't a huge deal (2 lbs?) but the fact that 2 lbs of rotating weight has been shed might actually be noticable.  I'm still saving and hopeing to find a set of used BST's out there.  $50 a week into savings, but it'll still take a more than a year to buy a new pair  :-[
AND, the headlight fairing Ti bolts I ordered came in, so now I can offer the lowered headlight fairing mod/gauges under triple as a complete "kit" with the proper bolts for the gauges.
