February 05, 2025, 07:46:31 PM *
Pages: [1] 2 3 ... 8   Go Down
Author Topic: Triumph Thruxton Mini Headlight Fairing (Now w/Pics)  (Read 41686 times)
Markus
« on: December 28, 2008, 11:52:45 AM »
Has anyone installed a Triumph Thruxton style headlight fairing on their Monster? I'm considering this on my M.
Thoughts? Looks like it'd be a fairly simple bolt-on install.
Thanks,
Mark
« Last Edit: February 27, 2009, 12:32:24 PM by Markus » Logged
2000 M966Sie
2007 ST3s ABS
www.eastcoastducaticlub.com
RBX QB
« Reply #1 on: December 28, 2008, 01:00:24 PM »
Verify the headlight diameter on the Thruxton, as the Monster has a larger headlight than your typical cruiser. Most bikes max out around 7", but the Monster one is larger.
Markus
« Reply #2 on: December 28, 2008, 05:46:23 PM »
I'll definitely check into the diameter of the Triumph vs the Ducati headlights. Thanks for the input!
2000 M966Sie
2007 ST3s ABS
teddy037.2
« Reply #3 on: December 29, 2008, 10:43:09 AM »
you could always swap headlights, too. if you're feelin' crafty waytogo
mmakay
695
« Reply #4 on: December 29, 2008, 10:28:48 PM »
I'd put money on it workin' perfectly.  No FHE, though...
- Mickey
Markus
« Reply #5 on: December 30, 2008, 05:49:41 AM »
Unfortunately the closest Triumph dealer isn't really local to me so i'll be posting on the RAT site for specs on the Thruxton headlight. If it seems like it'll work I'll try it this winter and post the result.
Thanks for the input everyone.
Mark
 Smiley
2000 M966Sie
2007 ST3s ABS
corey
'06 Tang/Black S2R800
« Reply #6 on: December 30, 2008, 06:35:04 PM »
i would expect to do some custom signal bracketry for this trick.
looks like the thruxton fairing is going to intercept stock monster signals for sure.
RBX QB
« Reply #7 on: December 31, 2008, 05:23:58 PM »
So I found myself at my local Triumph dealer this morning, looking for stuff. I measured a Thruxton headlight at 7 7/8" between the headlight mounts. The lense itself is about 7" even. Don't have my Monster in front of me, but this should give you enough to finish evaluating this option.
Markus
« Reply #8 on: January 04, 2009, 11:15:23 AM »
Great! Thanks for the measurements. The stock M headlight is 7" with a slight flare out to the chrome ring making it 7 3/8" where the glass runs under the ring. The headlight mounts are 7 7/8" apart, same as the Thruxton, i suspect it should fit without too many problems.
I'm running non-stock LED turn signals with custom mounting brackets so i think I should be able to trim the fairing enough to clear them.
Monster projects are never done. Cool
« Last Edit: January 04, 2009, 12:48:28 PM by Markus » Logged
2000 M966Sie
2007 ST3s ABS
squidwood
« Reply #9 on: January 04, 2009, 09:02:51 PM »
what are turn signals? laughingdp
hypurone
« Reply #10 on: January 05, 2009, 06:33:51 AM »
You know. The things that come as OEM equipment on every street vehicle made and NO ONE EVER USES!  Roll Eyes
Markus
« Reply #11 on: January 05, 2009, 08:29:22 AM »
 Grin
2000 M966Sie
2007 ST3s ABS
geoffduc
18 till i die
« Reply #12 on: January 05, 2009, 08:54:16 AM »
The problem with indicators is on most bikes they don't self cancel and if you are getting old and forgetful it's easy to ride for miles with the dam things winking  Embarrassed Embarrassed
2015 scrambler FT
2009 monster 1100s
« Reply #13 on: January 05, 2009, 09:33:51 AM »
This may be why so many old guys are on Harleys.  They have self canceling indicators that actually work.
Rob Hilding
« Reply #14 on: January 05, 2009, 07:08:22 PM »
We are (on Harleys ). And they do(work).
But unless there is some significantly (relatively speaking) lean angle and acceleration out of the corner - they don't work - otherwise they're great
On topic - I like that faring - can't wait to see it on your bike.
Pages: [1] 2 3 ... 8   Go Up
