696 going to the shop...
Started by Slag, December 29, 2008, 08:16:57 AM
Duc L'Smart
Quote from: Slag on December 31, 2008, 03:24:22 PM
The new battery compartment and heat shield were done today.
Cool. I need that done...
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS, '73 BMW R75/5, '67 Ducati Monza 250 Bevel Drive, '63 Vespa GS 160
RichD
I was in the process of relocating the ECU and VR anyway... and the recall came out.
I've had way too many heat related failures -and my warantee is turning into a pumkin in a month...
I've averaged three new ECU's a year!
-which is one thing under warranty, but unacceptable if I'm paying for them!!!
DFW-MFer!
RichD
Quote from: Slag on December 31, 2008, 03:16:44 PM
Only 5k miles. They said it could make it a bit longer, but went ahead and let them replace it.
Wow.  I get about 13,000 miles per chain on the 1098 (and that's with a 14t front sprocket).
I use the DID VM525 chain, Maxima chain wax, and clean chain & sprockets with PPG wax & grease remover.
Are you running 520 chain?  Lube? ...?  ???
DFW-MFer!
Slag
I have been rather pathetic when it comes to chain care. I take full responsibility.
Samsonite
Quote from: Slag on January 03, 2009, 01:02:41 AM
The man does not own a bottle of lube
ummmmmm........chain lube [roll]
Suzuki DS 80   Suzuki SP 125   Suzuki GSXR 1000   Ducati M600   Ducati SC 1000   Ducati S4R 1000   Ducati PS1000LE   Ducati 1098S   Yamaha YZFR 1000   Yamaha YZFR 600   Ducati Sport 900   Yamaha YSR 50   Triumph Daytona 600   2006 Suzuki GSX-R 600
Slag
Quote from: Tommy on January 03, 2009, 08:27:10 AM
There is one on my kitchen table. Granted, I do not own it. I have read the back. Does that count?
Samsonite
Quote from: Slag on January 03, 2009, 08:32:34 AM
thief
Duc L'Smart
Quote from: RichD on January 02, 2009, 10:56:17 PM
I thought the 1098 had a 520 chain?
Ronr
Slag
The 696 is on a test ride, and then it should be ready to go. I do not have the entire scoop yet, but relays were involved.
Duc L'Smart
andym
What did they do about the mirror(s)?
M696 Dark
Slag
Quote from: andym on January 03, 2009, 11:08:49 AM
Gave us a new mirror. No luck on the credit towards bar end mirrors.
andym
Quote from: Slag on January 03, 2009, 11:10:45 AM
Good to know, I won't see what it takes to make mine fall off again.
M696 Dark
