Multistrada Re-construct -- DONE
Started by Triple J, January 25, 2009, 02:22:08 PM
Alexandre
wow, that is a realllyyyyyyy cool multi and a reallllllyyyyy cool bike overall.
i love it and i want my own multi reconstruct soo muchh!!!!
[moto]  [moto]  [moto]  [moto]  [moto]  [moto]  [moto]  [moto]  [moto]
jftoha
#76
Wow!!! That is looking amazing!! I have been following the progress and I did not expect it to look this good.
There is one thing that in my view could look better though. I think that lowering the headlight and clocks would make the lines flow a bit better front to back. I hope you don't mind but I took the freedom of "Photoshoping" your photos to illustrate what I am talking about. In any case, it has come out very very good and professional.
Existing
Lowered Headlight
Existing
Lowered Headlight
Got Duc
I like it with the lowered headlight even more!  [thumbsup]
mookieo2
That looks really good. Beautiful job.
Ever think about chopping that last section off of the tail?
Mojo S2R
DucatiTorrey
+1 on headlight and getting the tail finished up a bit more. Cant wait to see it with taillight assembly and pipes
what are you gonna do for pipes?
  - real place
Triple J
The headlight actually has been lowered since these pics were taken. The turn signals were hitting the tank so I had to lower it for clearance. I'm also probably going to use the higher sets of mount holes, which will in turn lower it a tad more. Not sure if I can get it as low as the photoshop due to the clamps and fork diameter...but maybe close. I agree it does look better lowered.  [thumbsup]
Gauges are where they are. It's a custom machined bracket. Also, if I lowered them any more it'd look silly from the top due to the height if the ignition unit.
Thanks  for all of the compliments guys!  [thumbsup]
Quote from: mookieo2 on March 22, 2009, 06:32:24 AM
I wanted to, but the clamp that holds the pillion seat cover on is mounted on a cross member at the very end of what's left. Cutting it off would require the pillion cover to be permanently attached with fiberglass to the tank, not allowing for a pillion seat to be used, and permanently covering the gas tank beather valve. In the end I didn't want to do that.
Cleaning up the rear is tough on this bike as there was originally a set of rear fairings on it. I think it will look a little better with taillights/turn signals/plate on it though. There won't be so much empty space to focus on then.
Quote from: ducatitorrey on March 22, 2009, 07:24:48 AM
I have a single can from Competition Werkes. Check the 1st page...there's a pic of the can. I just have to get a piece of exhaust pipe welded up so I can mount it at the angle I like.
Triple J
#83
OK...in response to DMF suggestions...lowered headlight.  [cheeky] This is about as low as I can get it...maybe 1/2" more if I used the highest mounting holes on the headlight, but then it would stick out further. The forks get fatter right at the bottom of the clamps so they can't go down any more.
I think it definitely looks better...thanks for the suggestion.  [thumbsup]
Not as good of a pic...it sucks outside right now.  :-\
you're gonna kill me for saying this, but i really think the 696 headlight in all black would look great on this.
damianS4RS
Wow man great job! That thing looks great! I like it with the lowered headlight as well. I think the stacked look goes well with the flow of the bike.  [clap] [clap]
Quote from: Raux on March 22, 2009, 11:52:06 AM
Alright, boys. Get the pitchforks and torches.
yes in a whisper
Triple J
Yeah, it probably would. Too late now though!  [cheeky]
WOW WOW WOW. This is fantastic.   [clap]
