FAQ: Short Riders
Started by somegirl, May 13, 2008, 02:21:37 PM
http://motowheels.com/i-8585531-corse-dynamics-ride-height-rod-748-998-hm-mts1000-m620-695-m1000-s2r-s4rs-s4-st.html
You'd have to check how much shorter, at the shortest setting 245mm, this is in comparison to your stock rod.
Remember that adjusting the rod will adjust the ride height more (the rocker arm has a 1:1.37 ratio and the seat is positioned further back than the rocker arm pivot) Not a big issue - just take good measurements as you go along.
It's also wise to lower the front accordingly - or more if you like sharper turning.
Quote from: GirlfriendsDuc on October 20, 2012, 01:55:02 PM
Hey All,
One of the main reasons I joined this forum was to learn more about adjusting the riding height of the '05 Monster 620.  My girlfriend is about 5'3" and she still has a little trouble moving her bike around and feeling fully confident on inclines and parking, etc.  We've had the seat shaved and this helped, but the incline on the back of the seat still keeps her higher than ideal.
I've been looking at the rear suspension linkage trying to figure out if there was a way to lower things that way.  Then I found your site and read about an adjustable dogbone link.  Sounds like a perfect fix -- only the old web links to suppliers no longer seem to work.
Anyone know where I can find such a part for sale?
Thanks,
Dan in East Bay
Year and model?
freeclimbmtb
2011 Monster 796 ABS
Missed it.
Get the link posted by stopintime.  Lower the front the same as the back to maintain stock geometry.
SuperJetGirl
Hi All
I ride a Ducati monster 696, in which I am looking at this low seat to purchase....
http://m.ebay.com/itm/151564988913?nav=SEARCH
The stock cowl needs to be removed... Can anyone tell me how easy or hard this is to remove?
I read other posts about removing a bunch of screws but not sure it's really that easy.... also someone mentioned something about the lock?  (I'm not really sure what that was about)
Also does anything else need to happen to get this low seat on or does it literally just snap on and I'm good to go? (Once cowl is removed)
Last question- does anyone have names of any other boots that add height for the vertically challenged besides the daytona's??
Any help would be greatly appreciated. Thanks in advance.
The seat is released from the lock with the key - off and on - 5 seconds.
Removing the cowl isn't required, but something you'd have to do to transfer yours to the new seat.
It's two bolts - one on each side - you can see the holes for them in the pictures in the ebay link.
[Dolph]
SuperJetGirl
Quote from: stopintime on January 25, 2015, 10:50:28 AM
[Dolph]
Ok. Thanks. Are you sure it's just two bolts for the cowl? I see the bolts but I want to make sure there are none underneath that aren't visible that will make this harder. Two bolts seems too easy.
Quote from: SuperJetGirl on January 25, 2015, 12:27:28 PM
Try it  [thumbsup]
Also, make sure the preload on the shock is set up properly for you.  Any decent shop should be able to help you with this.
SuperJetGirl
Quote from: stopintime on January 25, 2015, 02:29:18 PM
Try it  [thumbsup]
So I didn't realize the cowl was part of the seat. I thought they were 2 separate pieces. So I didn't need to do anything. Ha!  Oops. My bad. Anyways, thanks for your help! 😃
