February 24, 2025, 07:36:13 PM *
Pages: 1 [2]   Go Down
Author Topic: Spark plugs  (Read 7675 times)
« Reply #15 on: December 04, 2010, 04:01:05 PM »
sugarpuss, if you have the time to do that, be my guest...
i was just teasing howie, i am sure he'll laugh out loud.
I'm underemployed...I have lots of time. Grin
I was teasing you counselor...lighten up a little. Kiss
Enjoying the ride
« Reply #16 on: December 04, 2010, 05:25:26 PM »
NGK DCPR8E part #NG4339, your bike will love them.  About $4 each here in the US.  If you can't find them in Panama our sponsor, California Cycleworks will be glad to send you a pair.
http://www.ca-cycleworks.com
I'm using the OLD NGK DCPR8E ... the Iridium ones got fouled ...
I know Chris can send me some plugs ... Just wanted to know if someone had FHE with the other brands ... still have 2 more of the NGK ones ... somewhere in the house ...
« Reply #17 on: December 04, 2010, 10:16:52 PM »
Both of you made me chuckle.
So, when are they going to replace or plastic tanks with the previously used metal tanks Cheesy
Langanobob
« Reply #18 on: December 05, 2010, 05:25:40 AM »
Hey, nice thread, anyone has had experience with BOSCh spark plugs? They show a P/N XR5DC ... I still have to order or purchase at stealership here ... I had Champions as OEM and they worked great ... changed to iridium and also worked great ... until ... well, using 'good old used plugs' at time of writing ...
If any Ducati tech can share some light on the BOSCH product ... TKS!!!
I think most if not all of us stick with NGK.  If you're having plug fouling problems with the correct heat range NGK chances are there is something else wrong, like a bad wire,  very rich mixture or excessive oil getting into the combustion chamber.  Sorry if I can't answer your question about  Bosch plugs.  I've used them in cars without any obvious problems but I don't think that relates at all to Ducati use.  Can you post a closeup photo of your fouled plug(s)?  Not that I have any talent for diagnosing problems based on internet plug pictures but maybe someone else can help.
Enjoying the ride
« Reply #19 on: December 05, 2010, 05:39:01 AM »
It was an issue discussed in another posting I did a couple days ago ... regarding 'exploding and throwing flames thru the exhaust' ... it was a one time only thing that took care of itself, even though it fouled my iridium plugs ...
Just asking about the other brands since I'm now 'working' for a company that distributes Bosch and the owner can get me a box[min order] of the correct ones for my bike ... well, actually, for many Ducatis ...
« Reply #20 on: December 05, 2010, 05:43:45 AM »
I'd run the Bosch plugs without hesitation. They make good products.
I think the reason we all tend to use NGK is marketing and availability.
« Reply #21 on: December 05, 2010, 05:54:26 AM »
I'd run the Bosch plugs without hesitation. .
no pun intended?
bang head bang head bang head bang head
« Reply #22 on: December 05, 2010, 06:00:33 AM »
no pun intended?
laughingdp
Enjoying the ride
« Reply #23 on: December 05, 2010, 09:04:18 AM »
Thanks for your opinion hdp ... btw, 31°C, sunshine and no rain in forecast ...
hillbillypolack
« Reply #24 on: December 05, 2010, 01:05:35 PM »
When you install your new plugs, dab a bit of anti-seize paste on the threads.  I just swapped plugs in the S2R, and whoa were they coarse feeling (original plugs).  Aluminum heads and steel plugs don't always play nice.
Also, get somewhere close to torque specs for obvious reasons.
Enjoying the ride
« Reply #25 on: December 05, 2010, 02:07:52 PM »
thanks hillibillypolack ... i always do ...
now, can someone tell me if i can install champion ra4hcx ... one local parts dealer has those for $3.25/ea ...
dark_duc
2008 S4RS Tricolore
« Reply #26 on: December 18, 2010, 06:12:36 AM »
I tried searching to find out what years the NGK 4339's are replacements for but couldn't nail it down.  Anyone know if they are the correct ones for my 2006 620?
« Reply #27 on: December 18, 2010, 09:01:17 AM »
Yes.
dark_duc
2008 S4RS Tricolore
« Reply #28 on: December 18, 2010, 09:14:38 AM »
Thanks!
Pages: 1 [2]   Go Up
