oil question
Started by chirrin, February 13, 2009, 04:32:41 PM
chirrin
whats up guy is been i while i got a 2000 ducati monster engine 750 wet clutch and im about to do the first oil change and i bought mobile fully sintethic oil w5 30 cause is hot in here i live in tucson arizona is it ok if i put this kind of oil or what should i put?  and other question is the same oil that works in the wet clutch i mean the clutch is integrated into the engine and use the same oil? thanks
needtorque
Yes, the clutch and engine share the same oil.  I used Mobil one full synthetic in my 01' m750 and had no problems but I have heard of others saying the clutch slipped when they used it.
Who insures the FDIC?
ScottRNelson
Ducati recommends 20W50 for most Monsters in most weather conditions.  Don't you think 5W30 might be a bit thin?
10W-40, 15W-40, 10W-50, 15W-50, 20W-50 are all acceptable, in your Texas heat my recommendation would be 20W-50, preferably 15 02 20W-50, and in the case of your wet clutch, moto specific.  5W-30  is way too thin, and probably energy conserving, almost guaranteeing clutch slippage.
DuciD03
Quote from: howie on February 13, 2009, 08:18:39 PM
I'm using 15w 50 fully synthetic Motul V300 in the North West where its cool; I might have noticed a bit of clutch slippage but maybe not.
.... all the world is yours.
Turf
15-50 silkoline synth in my bikes
5-30 is too thin in my opinion
"Some oil is better than no oil, synth is better than dead dino"
Keld
Quote from: Paper5tr3et7 on February 14, 2009, 12:10:55 AM
+1
I would never use that thin an oil. And in Arizona my oil would be ?w-50.
chirrin
i was reading some posting info about oil change and it says that a net or strainer that helps to keep the oil pump clean has to be cleaned when the oil change is being performed do i have to do this in my ducati? if so where exactly is located and what is the procedure?
2000 ducati monster 750 dark with 12000 miles
The strainer should be cleaned periodically.
It is located on the right side just below the side cover. There is a 21mm 'bolt' that you remove. On your bike the screen is attached to that bolt.
That nut can also be a bear to break loose.  I run Rotella synthetic in 15-40 on my '99 M750.  No slippage w/ stock clutch and 31,000 miles ~
JM
Langanobob
QuoteI run Rotella synthetic in 15-40 on my '99 M750.
I've been using the Shell Rotella synthetic in various machines for a long time with no problems.  In my Duc I still use the Mobil 4t synthetic that Georgecls used to recommend but the Rotella is a LOT cheaper at (aaargh) Walmart in gallon jugs and it's probably a safe bet that for all practical purposes my bikes can't tell the difference.  I have a neighbor who is a union housepainter and I have to be careful about mentioning that I buy oil at Walmart.   :)
