April 25, 2024, 12:19:34 AM
DFWM
Sidestand switchythingy bypass...
Topic: Sidestand switchythingy bypass... (Read 8807 times)
Duc L'Smart
May 14, 2008, 05:19:05 AM »
Gettin' serious here... Popped the sidestand off the 1098 for track days.
Is there an easy way to bypass the switch?
Anyone know which wires to jump??
Grazie Mille
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS,
'73 BMW R75/5
'67 Ducati Monza 250 Bevel Drive
'63 Vespa GS 160
Dallas 1098
You've got hope. I have skill.
Re: Sidestand switchythingy bypass...
May 14, 2008, 05:23:40 AM »
Quote from: Duc L'Smart on May 14, 2008, 05:19:05 AM
Grazie Mille
Scott,
Those switches normally work on the ground side. If no one knows which specific wires, we can test them Sunday with a volt / ohm meter.
08' 1098 AKA "RAZZO"
Duc L'Smart
May 14, 2008, 05:28:11 AM »
Quote from: Dallas 1098 on May 14, 2008, 05:23:40 AM
Scott,
Thanks Jeff-
The switch is orientated horizontally, so all three contacts are parallel to the ground!
'73 BMW R75/5
'63 Vespa GS 160
♣ McKraut ♣
touched by his noodly appendage
May 14, 2008, 05:29:36 AM »
Quote from: Duc L'Smart on May 14, 2008, 05:28:11 AM
Thanks Jeff-
unless the sidestands are now somehow technologically advanced...you can use a paperclip.
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
hiero
May 14, 2008, 05:33:28 AM »
all the previous switches had three contacts, but only two wires, take another look and see what you got...
2000 Monster 750
1999 748
YELLOW!!
Duc L'Smart
May 14, 2008, 05:39:04 AM »
Quote from: McKraut on May 14, 2008, 05:29:36 AM
Thanks, man... I'll swing by AMS & pick one up. Do you have the DP part number?!?!?!?!?
'73 BMW R75/5
'63 Vespa GS 160
♣ McKraut ♣
May 14, 2008, 06:59:58 AM »
Quote from: Duc L'Smart on May 14, 2008, 05:39:04 AM
i think you can get in touch with office depot for that...but they only have the appropriate clips that you need at the italy locations, unfortunately. luckily, they're only $.99! it'll just take four weeks to be shipped here..
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
RichD
May 14, 2008, 07:30:07 AM »
Grazie Mille
You can just unscrew the switch from the sidestand, turn it (like a knob) where the center would be if it was still attached and the kickstand "up"... run a zip-tie through the middle (to ensure it doen't rotate/vibrate) and tie it up.
That way you have not unhooked anything.
I think it is a 6mm or 8mm screw in the middle of the kickstand to remove it.
DFW-MFer!
Duc L'Smart
May 14, 2008, 07:36:17 AM »
Thanks man, good suggestion
But I want the d@mn thang GONE!!!!!!
'73 BMW R75/5
'63 Vespa GS 160
James.M
May 14, 2008, 09:22:21 AM »
what I did on my race bike was, split the cable and made them contact each other... just continued the circuit.
Duc L'Smart
May 14, 2008, 09:32:54 AM »
Thanks James. I just thought, well, if someone ever wanted to hook that switch back up...
'73 BMW R75/5
'63 Vespa GS 160
Dallas 1098
May 14, 2008, 09:43:15 AM »
Quote from: JamesMcCain on May 14, 2008, 09:22:21 AM
James,
Do you remember if you had two ot three wires? Did you connect the Green and black wire together? That is my guess but I have not put a meter on the harness to check it. The circuit is normally open and the sidestand contacts and closes the circuit, basically grounding it. My only concernis that the Neutral indicator light on the dash is also part of this circuit. There could be a potential current draw, unless a diode is put in-line on tne Neutral indicator light wire, which I am guessing is the third wire in the harness. Again, I have not confirmed this witha meter... yet.
Jeff
BarneePhife
Nip it! In the bud!
May 14, 2008, 09:43:44 AM »
Quote from: Duc L'Smart on May 14, 2008, 09:32:54 AM
Yeah, you better take care of
my next bike
. [moto]
Ducati
SportClassic 1000
1978
Yamaha GT 80
Ambition is a poor excuse for not having sense enough to be lazy.
James.M
May 14, 2008, 09:50:18 AM »
you can always un-twist the wires, I cut 1/3 into the wire so if I needed to put it back to the kick stand you can... just had electrical tape on it.
Quote from: Dallas 1098 on May 14, 2008, 09:43:15 AM
James,
Jeff
Yes its 2, green and black, just splice and tie-together... there wont be any issues, no groups, no potential current draw, nada... I can show ya on monday if need be, but its not necessary to even do this for a track day... the kickstand doesn't fall or anything...
RichD
Reply #14 on:
May 14, 2008, 09:59:15 AM »
Quote from: JamesMcCain on May 14, 2008, 09:50:18 AM
...I can show ya on monday if need be, but its not necessary to even do this for a track day... the kickstand doesn't fall or anything...
True that.
If you drag the kickstand in a turn on a 1098 your going to scrape the paint on your helmet too.
DFW-MFer!
