November 06, 2024, 10:30:07 PM *
Pages: 1 ... 7284 7285 [7286] 7287 7288 ... 14369   Go Down
Author Topic: The Official "Say Anything" Thread  (Read 7500507 times)
« Reply #109275 on: May 25, 2012, 02:39:57 AM »
I hope it's not Franks turn with the feeling...
I'm not a fan of the PVC...
Why not?
The Architect
« Reply #109276 on: May 25, 2012, 02:40:04 AM »
You have a can of HTFU?  Grin
I do.  It's actual a 55 gallon drum left over from when they built my house.  They accidentally left it in the basement.  It does have a warning label on it: may cause contractor to frame a deck with finish nails and use 20d nails to secure deck boards.  May also cause contractor to secure deck framing to concrete foundation with only 3 nails.  Etc.....
Are you sure you want it?
« Reply #109277 on: May 25, 2012, 02:42:03 AM »
You should see how we attached the deck to the foundation through the foam...
Pretty resourceful if I must say.
I don't need 55 gal.
Can you pour me off a qt? Grin
Ddan
Some of my best friends are whores
« Reply #109278 on: May 25, 2012, 02:44:20 AM »
Why not?
Mostly the cost, I just don't see how it's worth it.
                    flogged successfully  NHMS  12 customized.  Twice.   T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
« Reply #109279 on: May 25, 2012, 02:44:51 AM »
morning
« Reply #109280 on: May 25, 2012, 02:46:25 AM »
You have to look past the initial cost and to the cost of maintaining/replacing wood.
I'll never touch this stuff again once it's up and finished.
morning
uh huh...
« Reply #109281 on: May 25, 2012, 02:47:55 AM »
there is wood that lasts practically forever too, little pricey though
The Architect
« Reply #109282 on: May 25, 2012, 02:48:58 AM »
They took it away from me last week.  They said I over used it.  I only had it for two weeks.  Unfortunately a lot can bappen in two weeks.  I tried to explain that it wasn't my fault, outside force.  They didn't care.
« Reply #109283 on: May 25, 2012, 02:50:15 AM »
...and requires maintenance...
« Reply #109284 on: May 25, 2012, 02:52:19 AM »
no, supposedly you can just set and forget ipe.
It does gray but that's it.
« Reply #109285 on: May 25, 2012, 02:55:31 AM »
What kind of wood?
Cedar?
The Architect
« Reply #109286 on: May 25, 2012, 02:57:04 AM »
 He's right.  And it's beautiful stuff.  But if you think pvc is expensive and difficult to work with, ipe or otherwise know as ironwood is not for you.
IMAG0146 by anzalone22, on Flickr
It was supposed to be a simple fix, $4k later and endless hours of frame repair and I'll have a deck again.  bang head
Ddan
« Reply #109287 on: May 25, 2012, 02:58:18 AM »
uh huh...
Properly installed pine will last a long time with fairly minimal maintenance.  It wouldn't need any more care than your siding.
« Reply #109288 on: May 25, 2012, 02:59:25 AM »
but it supposedly has the same fire rating as concrete
wonder how much it would cost to build a whole house of it  laughingdp
« Reply #109289 on: May 25, 2012, 03:03:21 AM »
Finding pine that's high enough quality to look good isn't easy anymore. If you do find it it isn't cheap by any stretch of the imagination, and still requires more maintenance than pvc or composite siding.
...and besides...it's already painted.  Tongue
ironwood isn't in the budget...
« Last Edit: May 25, 2012, 03:20:45 AM by ducpainter » Logged
Pages: 1 ... 7284 7285 [7286] 7287 7288 ... 14369   Go Up
