happy afternoon to all . . .
had to kidsit the neighborhs oldest[10yrs] for a while .. . mom went out to run some errands and got stuck in traffic . . . when kid got home, nobody to open the door so he came over . . Max almost eats him alive . ..  this kid is afraid of his shadow ..  after a while they were playing like friends
evening.
Fun day at the track...watching. :'(
I like the track...
Im going to beed a new O2 sensor. I just replaced these last year but one of them went out already. Im going to get the BOSCH this time.
Quote from: Mendo Dave on May 06, 2013, 05:26:37 PM
I like the track...
Evening . . .
for the Jeep or MB?    not always the O2 sensor is the culprit . .  it may "fix" things temporarily, but, the whole ignition/injection system must be checked, coils, injectors, MAF sensor . . .I'll assume your Jeep has a 'close loop' system not 'open loop' where you have 2 O2 Sensors in from of the cat and 2 O2 sensors after ..  sorry, you've got an inline 6 . . so you have one before one after . . .check your cat, it could be faulty . . .if the MAF if "dirty" it will not read precisely and either tell the ECU to give more or less fuel . .. just my $0.02
now, time for a drink . . .
Quote from: Darkmonster620 on May 06, 2013, 05:52:57 PM
Evening . . .
Ill check the MAF i just got done changing the plugs. I changed the six on one side last week and changed the other six today. It was in between changes that the light came on. I have a feeling that it caused one to burn out.
I don't own a jeep. LMT is having trouble with hers though.
Quote from: Mendo Dave on May 06, 2013, 06:00:53 PM
12 plugs? what engine is that?
Quote from: Mendo Dave on May 06, 2013, 06:09:44 PM
3.2L V6 on the wagon
OK, on the Benz . . . . for some reason I thought you were talking about a Jeep !!!!
Its the first car I've owned that i actually kind of like working on.
When my dog walks around with the blanket draped over her, she reminds me of Mr Snuffleupagus
Quote from: Mendo Dave on May 06, 2013, 06:14:13 PM
in that case, you should check your 4 O2 sensors . . two before two after . . . also, might not be getting an EGR code, but, have it checked and/or cleaned, yes it can be cleaned . . .
btw, what codes are you getting?
I'm so tired . . .but, once I hit the pillow, all of it goes away . . .
Quote from: Darkmonster620 on May 06, 2013, 06:48:11 PM
I don't remember the code, but it says bank 1 sensor 2 i can recheck the code later.
Quote from: Mendo Dave on May 06, 2013, 07:08:25 PM
P0141 or P0140 . . .
Quote from: Darkmonster620 on May 06, 2013, 07:25:49 PM
I think its one of those. Specifically its the heater circuit.
Quote from: Mendo Dave on May 06, 2013, 07:32:57 PM
hope this helps . . . O2 sensor codes are one of the most diff to diagnose, correctly . . .
OBD II Fault Code
OBD II P0140
Fault Code Definition
The Catalyst Monitoring Oxygen Sensor evaluates the rear most Catalytic Converter's emissions-reducing capability. Code P0140 is set when there is no activity in the signal from the Rear Oxygen Sensor.
Symptoms
Check Engine Light will illuminate
In many cases, no abnormal symptoms may be noticed
In some cases, the vehicle will fail an Emissions Test
In many cases, the NOx emissions will be elevated
Common Problems That Trigger the P0140 Code
Defective Catalytic Converter
Faulty Rear Oxygen Sensor wiring or connections
Common Misdiagnoses
Oxygen Sensor is replaced when the problem is a defective Catalytic Converter
Oxygen Sensor is replaced when the problem is faulty sensor wiring or connections
OBD II Fault Code
OBD II P0141
The Catalyst Monitoring Oxygen Sensor evaluates the rear most Catalytic Converter's emissions-reducing capability. Code P0141 is set when the Rear Oxygen Sensor does not show signal activity indicative of closed loop fuel system operation within the required time.
Symptoms
Common Problems That Trigger the P0141 Code
Defective Rear Most Oxygen Sensor
Faulty Rear Most Oxygen Sensor wiring or connections
Common Misdiagnoses
Oxygen Sensor Sensor is replaced when the problem is a defective Catalytic Converter
Oxygen Sensor is replaced when the problem is an exhaust leak before the Rear Oxygen Sensor
