what temperature are you maintaining?
Oldfisti
Quote from: Ddan on January 03, 2014, 04:19:25 PM
How's it heating in this weather?
I can answer that.  Absolutely comfortable!  It's the warmest 65deg I've ever felt!
Not a cold spot in the house.
Ddan
Quote from: ducpainter on January 03, 2014, 04:25:38 PM
The drywaller sprayed...all one color. ;)
Right now the humidity is around 40% and has stayed that way throughout the process. There was a little condensation on the windows as all the mud and primer were drying, but that's gone now.
At 0 degrees the boiler is running, but at a really low firing rate, I think. At 40 degrees it doesn't run much at all.
Interesting that all day today, with the sun shining, the sunroom didn't call for heat while the other zone did.
But the drywaller is good  ;D
Quote from: Oldfisti on January 03, 2014, 04:30:54 PM
[thumbsup]
Ducati Monster Forum at
www.ducatimonsterforum.org
Quote from: lethe on January 03, 2014, 04:30:24 PM
I have the plumbers 65 degree temporary thermostats in right now.
Quote from: Ddan on January 03, 2014, 04:31:49 PM
I'm gonna charge him to remove the overspray from the beams. ;)
my house isn't faring as well
with it being currently zero out, one of my zones can't bring it above 68
The others are doing fine but I hear them running a couple times an hour as well
Quote from: lethe on January 03, 2014, 04:35:07 PM
That's the thing...
the boiler runs for a few minutes...then stops...then runs a few minutes..then stops.
The circulator for that zone runs pretty steady.
I haven't balanced the slab yet, but I'm starting to play with water temps a little. I don't want it to get too hot in the slab.
The zone that runs is much larger square footage wise. I also upped the flow rate as I have circulators with that option. The real issue is it's make the beast with two backsing cold out. The house is still comfy.
I know where my leakage is, it's the areas I haven't done work in yet
In the design/construction process there was a glitch...
I need to fill a gap at the slab edge.
Can't really do it at zero.
evenign . . .
had dinner with missus on way fome from the showrrom . . . didn't make the pain fo aqay
Wow, does the news make it sound like the weather back east is BAD, is it really all that?
Enjoy the dinner Carlos, whatcha having?
Quote from: red baron on January 03, 2014, 05:44:32 PM
Meh...
It's cold.
A little colder than early January should be. ;)
Had a rib eye steak with garlic mashed potatoe and salat
Oldfisti
Quote from: ducpainter on January 03, 2014, 05:49:22 PM
Meh...
It's cold.
-17deg here right now.  Our burner is firing on all cylinders.
brimo
Just back from the beach, should have stayed a bit longer, 41 deg here at the moment. Cranking up the aircon and a few  [drink] s will have to do.
From a story by RAT900
