That looked similar to my dog at the end of the video
BTW that line about the deadly black tarantula gives the Spider a bad rap. No Tarantula is known to be deadly at least not from the poison directly according to wikipedia.
However some peeps could have an allergic reaction  to the poison, or even have such a fearful reaction to the sight of one that they panic and run out into the street and get hit by a taxi.
back from pt . . . was gonna get a shower but no electricity means no water . . . I think about a reserve tank/pump everyday this happens . . .
well, at least for lunch I don't need water . . .
DesmoDiva
#169548
EveNing.
Took the dogs for a long walk.
Waiting for B to get home.
Baked pollock, local asparagus, and ??? for dinner.
No big plans for the weekend.
As much as you lose water C, I would invest in a reserve tank.
'01 ST4 Yellow
'02 ST4s Yellow
duccarlos
Long few hours. It's definitely fire drill Friday.
Needle99
Needle99
Quote from: duccarlos on May 15, 2015, 02:35:22 PM
Common saying?
Scoober1103
09 M1100 + stuff.
07 GSXR750 stock as a......
15 KTM Freeride 250r for hurting myself!
Quote from: koko64 on April 02, 2014, 02:52:23 AM
Don't buy cheap shit, it can cut your balls off.
evening . . .
ankle hurts a bit . . . slipped and rh ankle went from one step to the next . . . ouch
Quote from: DarkMonster620 on May 15, 2015, 11:48:17 AM
we have the same issue Carlos, but not with the same monotonous regularity that you have to put up with.   Why not install a small capacity (1000 litre?) elevated header tank?  Float valve controlled, it'd always be full for you to draw from when the power goes out.  Gravity feed will be sufficient water pressure for a "back up" supply - no pump required.
Quote from: ungeheuer on May 15, 2015, 05:56:20 PM
thought of that, missus no like how it looks .. .  women, looks over function . .. MOSTLY, not all . . .
DesmoDiva
Back.
Dinner and helped B replace the serpentine belt and tensioner pulley on the truck.
Got finished right before a downpour.
Hope all the meetings mean positive things in the future DP.
Ask her if she wants to be able to shower and flush the toilet.
How ugly could it be?
'01 ST4 Yellow
'02 ST4s Yellow
Quote from: DarkMonster620 on May 15, 2015, 05:58:24 PM
[roll]
She'll forgive you when the toilet can still be flushed.
Or if you really have to pander to appearance over practicality, install an array of several smaller tanks inside the roof space then.
