Quote from: KnightofNi on June 12, 2009, 12:14:51 PM
it's not the Hunns that are the problem. it's the gawd dam mongrolians.
they make awesome beef
JEFF_H
And how did they expect the Kings Horses to be of any assistance in the shell re-assembly process  ???
Quote from: JEFF_H on June 12, 2009, 12:50:27 PM
glue  ;)
JEFF_H
thanks for the humidor link...
think i need a new one  8)
those look to be the some of the same ones they sell through CI?
rgramjet
#40399
Hmmm, I am a cabinet maker.  Ive got a supplier that will make me a deal on Spanish Cedar.......Your humidor may have inspired me.  Im thinking The Cigar Dresser!
This is going to be expensive.... [thumbsup]
Are those Por Laranagas below the Hemingways?
-Sofadriver
rgramjet
Im sick of all these fuc'n rants!
;D
-Sofadriver
Porsche Monkey
when you conditioned it, did you let it sit and test the humidity before using it?  i've found that letting it sit for about a week with a cup of water in it helps.  wipe it down after 2-3 days and wait.
you'll always have a humidity DROP when you put cigars in as they suck the moisture.  you want the humidity to be about 5-7% over your target.
how is the seal on the hygro?  not easy to check this.
also, double check your hygrometer.  do you have a digital one?  calibrated?  the ones they usually include with a humidor are crap.  also, sometimes your home or the spot where you have it might just be bad
supplemental moisture might be needed too.  I use the gel cups for mine, I get them from Thompson.  most new humidors go thru quite a bit of conditioning before they soften up (the wood)..  it might just be so dry that the conditioning you did wasn't sufficient.
circle of life man..... circle of life
Quote from: bobspapa on June 12, 2009, 02:07:08 PM
although grilled horse is really quite tasty
teddy037.2
#40407
DERBY!
hankthe8th
#40408
^ Shit, I derby'd a derby. ^
Derby rant!
http://ducatimonsterforum.org/index.php?topic=25237.0
teddy037.2
ooh, god don't get me started.
I needed a cig at like 0900... and I don't even make the beast with two backsing smoke!
stupid make the beast with two backsing mgmt. they want equality, i'll give 'em equality.
