Ddan
How's the re-do in the shop going?  DId you figure out how to modulate the air-flow yet?
Ducati Monster Forum at
www.ducatimonsterforum.org
Quote from: DDDDan on June 21, 2009, 03:57:49 AM
I have a plan...
First thing I did was remove half the blades from the propeller
I'm going to simulate a leak by introducing outside air to the fan side of the exhaust filter.
I'll do that with a piece of duct and a damper.
Depending on the size of the duct I should be able to modulate from about 500-1500 cfm.
Everything else is done except for the coating which is ordered. I need to get an airless gun and hose for the pump I have. They're not cheap...neither is the coating.
The room is blindingly bright with the old coating peeled and the bad lights replaced/bulbs cleaned...I may actually be able to see. :o
Ddan
That sounds like a lot accomplished.  I like the air solution, pretty simple and it seems like it would have to work.
DesmoDiva
#41493
More Ning.   [coffee]
Happy Father's Day!!!
printer, awesome to hear that PT is going well.   [thumbsup]
Quote from: Mr Natural on June 20, 2009, 07:04:09 PM
We'll have kittens soon. :P
Just in time to sent a couple home in TiNi's bags at DIMBY.   [evil]
'01 ST4 Yellow
'02 ST4s Yellow
Quote from: DDDDan on June 21, 2009, 04:19:51 AM
I believe it will.
Now I just have to decide on a duct size and cut round holes. ;D
If it doesn't it means replacing the fan.
The only other upgrades will be a better floor surface and maybe some deflectors to divert air to the end walls. I noticed those two walls seem to be dead as far as airflow is concerned. It'll have to wait for another infusion of cash.
It's property tax time.
Ddan
How big are the round holes?  I've got hole saws up to 6" and a trammel for the router that will cut any size you want.
Quote from: DDDDan on June 21, 2009, 04:34:10 AM
Either 8 or 10"
I was gonna use a compass and a roto-zip.  :P
Ddan
Quote from: Mr Natural on June 21, 2009, 04:36:56 AM
Either 8 or 10"
You're gonna eat up zip-bits, but you can easily screw something the the base of the roto to use for a trammel.  It'll actually save on bits because you'll be cutting smoother.  If you're going through plywood, barnboard, nails, make a few passes.  Piece o' cake
Quote from: DDDDan on June 21, 2009, 04:41:27 AM
I have a carbide zip bit that nothing has been able to kill. It's 1/4 in.
I'll be going through FRP and wood. No nails involved.  ;)
Ddan
Quote from: Mr Natural on June 21, 2009, 04:45:40 AM
You haven't been trying hard enough then.    ;D
Sounds like you've got it figured, have fun making wood dust    [thumbsup]
Quote from: DDDDan on June 21, 2009, 04:57:04 AM
You have to check this thing out.
I use it in my die grinder too. ;D
mmmmm  dust
Ddan
Quote from: Mr Natural on June 21, 2009, 04:59:02 AM
mmmmm  dust
I've got some Zip bits that are 1/4 carbide burrs.  They work well in the Roto-Zip but you can do some damage with one chucked into a 3 1/4 HP router
Quote from: DDDDan on June 21, 2009, 05:10:29 AM
I'll bet.
Mo powah.... [laugh]
Ddan
-big yawn-
'Ning y'all...  Enjoying some  [coffee] with two of the dogs.  Trying to wake up mentally and plan out my day.
But, since the  [coffee] hasn't fired enough nuerons up yet, I'm here....yawning & typing.
Glad to hear (the member formerly known as DP) that your paint booth re-do is going well.  Here in CA if you try to install a new booth, all manner of demons dressed in suits attacks you from gov't agencies with expensive pieces of paper and fines and fees.  Evil make the beast with two backsers.  BUT, if you re-do your existing booth...hehehe...all happens under the radar and no-one's the wiser.  (tis cheaper too, eh?)
