The Architect
I have sooooo many uses for him!
I will eventually come out with a series of Where's Butters books.
Pip
Quote from: Buckethead on May 31, 2011, 02:18:43 PM
ZOMBIEEEEEE!!!!!1
RUUUUUUN!!!!
something like this in your mailbox: package in a Bosch box that says made in Germany with documentation in spanish saying it came from Panama
The Bacon Junkie
Quote from: Stella on May 31, 2011, 08:22:24 AM
I doubt that.
Well, maybe it's true after those weekend benders of yours....
;D
oh, nooo...  I sink.  Well, maybe I'll float better with that extra layer of boyancy I have around my mid-section now!  [laugh]
Jump Statler, JUMP!!!
Yay!  Zombie Pip is back!!!   ;D
[bacon]
Save the Brass...
See Statler,
WE ALL want to help you feel better ...
Hey guys,
This is with what I work, well, partly,
http://aa.bosch.de/boaa-default/Product.jsp?publication=3&prod_id=483&ccat_id=91&&language=en-GB
here's a pic, of the above bench and some of the other equipement I get to work with,
EPS815 Diesel pump and injector test/calibration bench; line, radial piston and common rail
KTS570 wireless OBD diagnostics/Reset tool
FSA750 OBD, exhaust gas diagnostic tool
so just got home
was very amused to look up the Bosch part number on the box the hot sauce came in to see it's a diesel fuel injection pump box  [laugh]
whatever it's for it's certainly smaller than the scary thing on the front of my engine  [cheeky]
not looking at the ingredients, just put some of the orange Caribeno sauce in my pasta.
orange is less hot than red and green right?
no, but not too bad either  [thumbsup]
Quote from: lethe on May 31, 2011, 04:02:03 PM
so just got home
It's the electronic control unit of the VP44 series radial pumps as the ones used in Cummings engines ...
Not sure on who's hotter than who ... Ask JM he's tried them all ... Me, seriously, I;m biased towards Caribeno ...
hehehe...  You just keep thinking that.
Caribeño is my favorite too.  Tasty stuff!
JM
Quote from: Darkmonster620 on May 31, 2011, 04:13:32 PM
those run at the same ridiculous pressures as my little car right?
Quote from: lethe on May 31, 2011, 04:16:47 PM
Nope, higher... the system on the GTD runs at about, at idle, 160MPa or 1600bar or 23206PSI; your injectors inject about 85mm3/hr... But this bench runs them all ... unless you have the last gen UIP[Unit Injector Pump] motor, that has one of these per cilynder, these are Pumps and Injectors in one unit, thus the name UIP ... Which produce even higher preasures ...
Statler
Quote from: Darkmonster620 on May 31, 2011, 04:48:19 PM
nope I have the single one that is driven by the timing belt, the pressure numbers I've read for it are 1800bar/26,000psi
Quote from: Statler on May 31, 2011, 04:52:45 PM
http://www.dupontregistry.com/autos/Search/DRauSearchDetails.aspx?itemid=999252
it's practical right?  I can put the Little One's carseat in the back?
right?
hello?
sure, if you want a boring family car  [cheeky]
right?
hello?
Looks nice, price seems correct for vintage ... and yes, most probably you'll be able to insall the carseat ... and get a suntan ...
