Quote from: ducpainter on June 04, 2011, 05:36:16 AM
You'll be fine with hoses. That compressor can be adjusted to put out much more if the need for more pressure arises.
Most blow guns are the OSHA type and won't put out more than 90 anyway.
I was thinking about machine requirements, so it's a non-issue.
The compressor can be adjusted?
Quote from: Darkmonster620 on June 04, 2011, 05:42:21 AM
as if you didn't know ...
Seriously.  I know the can be regulated down. I have no idea how you would increase the pressure ir cfm
OK ...
From what know, the  same knob, usually it comes set from factory so that it pumps out the 'usual' 90psi but it can be turned to pump out more depending on air tools and hoses ...
The one we had in the shop was set for 125~130 since we ran tire mounting machine, air tools the ocassional nitwitt who would park a car on top of ahose and turn the wheels ...
Quote from: Monsterlover on June 04, 2011, 05:41:48 AM
Why yes...yes it can.
You can adjust the cutout pressure and the pressure differential between on and off by the switch where the juice feeds in to the compressor.
This changes the shut off psi right?
Randimus Maximus
good morning, shop rats.
i get to jump on a jet plane or two back to colorado today.  [thumbsup]
while it's been nice seeing family, i'm getting a little stir crazy down here.
and i miss stella. and the b-dawg.
Quote from: Monsterlover on June 04, 2011, 06:13:09 AM
Both what?  Shut off and ...
the differential between on and off.
If you pull the cover on that switch you should see two screws with springs under them.
The larger is the shut off pressure. The smaller is the differential.
Quote from: Randimus Maximus on June 04, 2011, 06:15:00 AM
There's no place like home
Quote from: Darkmonster620 on June 02, 2011, 04:15:41 PM
JM,
What brand, if I may ask?
Cortech.  I've got a lot of their gear and really like it.  Their warranty service is good to, the not only replaced, but upgraded my gloves when the stitching was coming apart.
Morning all.  Eggs & bacon for brekki!
JM
Quote from: the_Journeyman on June 04, 2011, 06:24:36 AM
JM
Thanks ...
is that breakfast getting spicy?
Nah, I save the spicy for lunch & supper  [evil]
JM
Quote from: ducpainter on June 04, 2011, 06:19:08 AM
...exactly like the pressure switch on my old Davey water pump.
