Quote from: Dan on July 24, 2011, 06:36:05 AM
Did you check the breaker panel?
yes, mike did. it wasn't tripped... he reset it anyway.
Quote from: TiNi on July 24, 2011, 06:42:35 AM
How old is the well?
Well pumps can do some strange things over time that can cause them to stop working but not be 'bad'
Unfortunately they're usually hundreds of feet in the ground
Quote from: ducpainter on July 24, 2011, 06:45:38 AM
we think the pump is original to the house.. so 18 yrs old..
Quote from: Bick on July 24, 2011, 06:46:51 AM
More Ning, Every Body.  [coffee]
morning bick :)
Ddan
0 pressure on the gauge?  Sometimes the pressure switch will stick open, give it a couple of taps with something
Ducati Monster Forum at
www.ducatimonsterforum.org
 Morning!  Folkmoot is in full swing!  I barely have time to sleep, but it is fun!
JM
Quote from: TiNi on July 24, 2011, 06:48:48 AM
morning bick :)
I've seen pumps wiggle on the device that keeps them from twisting the pipe and wiring enough to damage the wiring.
Do you know how deep the pump is set?
Did Mike check the pressure switch?
That would be the easiest fix.
Quote from: Dan on July 24, 2011, 06:50:56 AM
Dan beat me to it...
also check to make sure the switch hasn't broken.
I had to replace mine recently because the spring anchor broke.
morning
glad I get water from the big tower a few hundred feet away, plenty of water even in a long blackout
hope it's an inexpensive fix for you
Good luck w/ the water situation Mel.
Off to a fair.
Quote from: ducpainter on July 24, 2011, 07:08:14 AM
Off to a fair.
win a blue ribbon for us  [thumbsup]
Stella
My dad used to fire a bullet into the well at our farm when it went dry.
He always had "an old indian trick" for everything and they usually worked.
[thumbsup]
Give it a try!    ;D
Good luck DP with the pie eating contest!
Morning everyone.   [coffee]    :)
thanks for all of the feedback on the well :)
not the switch, circuit or the guage  :-\
looking like it's going to be expensive
have fun at the fair nate!
Quote from: Stella on July 24, 2011, 07:28:06 AM
[thumbsup]
Give it a try!    ;D
morning stella :)
KnightofNi
hey everyone. taking a break from cleaning shit out of the upstairs rooms.
it's so freaking hot up there that when i come downstairs inot the room that is 79 degrees it's like walkin into a refridgerator.
Quote from: TiNi on July 24, 2011, 07:36:22 AM
sorry to hear...
