July 17, 2024, 01:31:04 PM
Statler
6438
6439
6440
6441
14331
Topic: The Official "Say Anything" Thread (Read 7268879 times)
Re: The Official "Say Anything" Thread
Reply #96570 on:
November 01, 2011, 03:49:46 AM »
morning
'05 620ie
Reply #96571 on:
November 01, 2011, 03:50:40 AM »
morning
power still out, day 4
it's out at work too, so at least I've got that going for me
cell signal is a little stronger too!
Reply #96572 on:
November 01, 2011, 03:51:37 AM »
Quote from: lethe on November 01, 2011, 03:49:46 AM
morning
you worky from home?
Quote from: TiNi on November 01, 2011, 03:50:40 AM
morning
keep feeding the fire.
Reply #96573 on:
November 01, 2011, 03:53:40 AM »
Quote from: ducpainter on November 01, 2011, 03:51:37 AM
no worky
using a vacation day to bring my wife up to the doctor and bring my car up to have a VW dealership clean up my roadside fix a little bit
Reply #96574 on:
November 01, 2011, 03:54:19 AM »
road side fix?
what'd I miss?
The best kind of whore is a
Reply #96575 on:
November 01, 2011, 03:55:36 AM »
He ran over something that tore up some wiring
Morning
Reply #96576 on:
November 01, 2011, 04:06:27 AM »
It's all coming back to me now...
Reply #96577 on:
November 01, 2011, 04:10:17 AM »
Quote from: ducpainter on November 01, 2011, 03:54:19 AM
road side fix?
what'd I miss?
Quote from: Monsterlover on November 01, 2011, 03:55:36 AM
Morning
some long piece of metal tore up through a plastic belly pan under the passenger seat and tore apart some wires.
big BANG followed by flashing lights
I pulled over, shut the car down, jacked it up, cut off what remained of a broken connector, wire nutted the wires back together and zip tied the whole mess back up so it wasn't touching the ground. Slowed me down by maybe 15 minutes. Checked the code later that was stored (the fix got rid of the flashing lights) and it was the exhaust gas temperature sensor.
Reply #96578 on:
November 01, 2011, 04:11:06 AM »
Quote from: ducpainter on November 01, 2011, 04:06:27 AM
Construction on the brain dp?
Me too
Reply #96579 on:
November 01, 2011, 04:14:35 AM »
Quote from: Monsterlover on November 01, 2011, 04:11:06 AM
Me too
I'm so friggin' scattered right now from everything that's going on it's ridiculous.
Of all the projects I've ever undertaken this one is providing the most stress I've ever felt.
Add in the fact I'm a month behind and it gets even more fun.
The consolation is the end result.
I'm going to be warm next winter.
Reply #96580 on:
November 01, 2011, 04:17:57 AM »
Quote from: ducpainter on November 01, 2011, 04:14:35 AM
70 degree winters from then on. You do control this stuff you know.
Reply #96581 on:
November 01, 2011, 04:20:30 AM »
Quote from: lethe on November 01, 2011, 04:17:57 AM
most likely...
If that's the result, so be it.
Insulation works in the heat too.
For $50 you can touch my
Reply #96582 on:
November 01, 2011, 04:58:14 AM »
You're moving to California?!?
Enjoying the ride
Reply #96583 on:
November 01, 2011, 05:02:46 AM »
So far, dry and sunny ... dp, keep it this way !!!
Reply #96584 on:
November 01, 2011, 05:05:52 AM »
Quote from: peeny on November 01, 2011, 04:58:14 AM
not likely.
6438
6439
6440
6441
14331
