February 11, 2025, 11:26:42 AM
2009 norton 961
Topic: 2009 norton 961 (Read 22349 times)
tristantumble
2009 norton 961
March 24, 2009, 06:08:30 AM »
looks like this will actually be available mid 2009, can't comment on anything else but the looks- and it looks GOOD.
more info:
http://www.totalmotorcycle.com/photos/2009models/2009-Norton-961Commando.htm
07.695 (sold)
07. sport 1000 biposto
sroberts152
Say hello to my
Re: 2009 norton 961
March 24, 2009, 06:21:58 AM »
That is really nice. It looks like they took the retro look and upgraded all parts for safety and performance - braked, shocks, rear tire. This is where it looks like they have succeeded where Triumph failed in doing their Modern Classics like the Bonnie and the Thruxton.
I like it.
TiAvenger
Re: 2009 norton 961
March 24, 2009, 06:22:38 AM »
Big Troubled Bear
The wrong side of normal
98 m900 sold, Red 696
Re: 2009 norton 961
March 24, 2009, 06:34:53 AM »
Me likey
Got Duc
Re: 2009 norton 961
March 24, 2009, 06:37:44 AM »
MaxPower
Re: 2009 norton 961
March 24, 2009, 06:46:56 AM »
Quote from: TiAvenger on March 24, 2009, 06:22:38 AM
Sacrilicious....
Nobody snuggles with Max Power. You strap yourself in and feel the Gs!
2003 M620i.e.
♣ McKraut ♣
touched by his noodly appendage
Re: 2009 norton 961
March 24, 2009, 07:23:56 AM »
gorgeous
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
BellissiMoto
Re: 2009 norton 961
March 24, 2009, 07:35:14 AM »
Those pictures have been around for at least 4 years now, and while it is a beauty of a bike, that would no doubt be fun to own and ride, we have seen stories touting their production, and soon to be availability for the same 4 years.
I definitely hope it happens.
Last Edit: November 28, 2009, 05:13:04 AM by BellissiMoto
corey
'06 Tang/Black S2R800
Re: 2009 norton 961
March 24, 2009, 09:06:09 AM »
BST wheels!
For $50 you can touch my
Re: 2009 norton 961
March 24, 2009, 11:34:53 AM »
I've been saying for years if they make that, I'll buy one.
If they make it-I'll still buy one. Anyone have any info on preordering?
Any info on how to best apologize to the wife?
That is all.
DLSGAP
Re: 2009 norton 961
March 24, 2009, 12:42:56 PM »
An old Norton Commando has long been on my list of bikes to own. I rode an 850 when I was 15 and LOVED it. this new bike.. if it ever actually gets put into production... has all the styling i love about the old nortons.. I sincerely hope they make it and that I win the lottery so i can buy one
Engine and transmission
Displacement: 961.00 ccm (58.64 cubic inches)
Engine type: Twin
Stroke: 4
Power: 80.00 HP (58.4 kW)) @ 6500 RPM
Torque: 65.00 Nm (6.6 kgf-m or 47.9 ft.lbs) @ 5200 RPM
Compression: 10.1:1
Bore x stroke: 88.0 x 79.0 mm (3.5 x 3.1 inches)
Fuel system: Carburettor. Twin 39mm Keihin FCR
Valves per cylinder: 2
Ignition: Crank fired electronic
Starter: Electric
Cooling system: Air
Gearbox: 5-speed
Clutch: Cush drive clutch
Physical measures
Dry weight: 188.2 kg (415.0 pounds)
Seat height: 813 mm (32.0 inches) If adjustable, lowest setting.
Wheelbase: 1,435 mm (56.5 inches)
Chassis and dimensions
Frame type: 4130 chromoly steel
Rake (fork angle): 24.5°
Trail: 102 mm (4.0 inches)
Front suspension: 43mm Ohlins RSU - Adjustable preload, compression, and rebound damping.
Front suspension travel: 140 mm (5.5 inches)
Rear suspension: Ohlins reservoir-style twin shocks - Adjstable ride height, preload, compression, and rebound damping.
Rear suspension travel: 102 mm (4.0 inches)
Front tyre dimensions: 120/70-X17
Rear tyre dimensions: 180/55-X17
Front brakes: Single disc
Front brakes diameter: 320 mm (12.6 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Exhaust system: 1 3/4 inch header system with merged collector and twin mufflers with catalytic converters.
Speed and acceleration
Power/weight ratio: 0.4250 HP/kg
Other specifications
Fuel capacity: 17.03 litres (4.50 gallons)
Color options: Black
Two things I don't like off the bat... lack of inverted forks, and lack of fuel injection...
Last Edit: March 24, 2009, 12:47:19 PM by DLSGAP
Damien
'07 Kawi ZX-10R Candy Plasma Blue
Draggin Knees since 1988
Monster Dave
Re: 2009 norton 961
March 24, 2009, 12:56:28 PM »
I like it, but I think that exhaust is
It looks beefier than the GT1000 which I like. That rugged beefy old school look is sweet.
swampduc
'99 996, '07 S2R1000,'08 1098s, '12 1199s
Re: 2009 norton 961
March 24, 2009, 01:06:05 PM »
Quote from: DLSGAP on March 24, 2009, 12:42:56 PM
+1. You use BST wheels, and then a conventional fork?
Respeta mi autoridad!
jerryz
Re: 2009 norton 961
March 24, 2009, 02:53:52 PM »
It will be 2010 before the bike is produced as thay have to get the fuel injection sorted for Euro 3 before it can be sold anywhere .But it is happening.
herm
Re: 2009 norton 961
Reply #14 on:
March 24, 2009, 03:30:03 PM »
Quote from: jerryz on March 24, 2009, 02:53:52 PM
looking forward to that..........
love the look though!
