January 10, 2025, 08:51:28 AM
2000 rebuild part suggestions
Topic: 2000 rebuild part suggestions (Read 3565 times)
pitbull
April 14, 2009, 03:38:42 PM »
The crashed 2000 900ie I picked up is apart, the engine is in being welded where it cracked at the rear bolt mount and the frame is being straightened where it was tweaked at the rear. The tank and fender go to the painter tomorrow and I've picked up several of the parts I needed and only have a few things left to get. I'm looking for some replacement suggestions.
Does anybody have any ideas for the gauges (instrument cluster) or am I stuck looking for a used OEM set?
Does anybody have any suggestions for replacement front brake lines?, as the stock ones broke where they mount to the levers. Should I look for used used, stock lines or should I upgrade?
When I get everything back from paint and repair and start the rebuild, I'm sure I'll have many more questions to ask in the Tech section...........but I promise to post pics.
weemonster
weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Re: 2000 rebuild part suggestions
April 14, 2009, 03:47:15 PM »
Ducati performance Frentubo kevlar lines are very pretty.
pretty expesive tho.
Markus
April 14, 2009, 04:47:24 PM »
Quote from: pitbull on April 14, 2009, 03:38:42 PM
You're likely to have a hard time finding used OEM gauges for your Monster as the 00-01 M900ie bikes used gauges specific to these years. The 900SSie tach won't work, although the speedo may. I looked high and low for a used tach to replace the one I damaged in a crash and eventually gave up and bought a NOS one. It was spendy, but it plugged right in. You may have better luck than I did finding used Monster gauges though.
If you end up looking to the aftermarket, check these guys out:
www.motogadget.com
. Their ChronoClassic is awesome!
2000 M966Sie
2007 ST3s ABS
www.eastcoastducaticlub.com
Scooter-Trash
April 14, 2009, 04:55:31 PM »
Yeah, the 2000-2001 Tachs were single-fire, so any set up from years prior will only read 1/2 the RPM it should and later model years aren't compatible.
You might find one on fleabay, but I highly recommend the motogadget as it's a sexy beast.
I have one of the old octopod tachs, but I want too much money for it (because I don't really want to sell it
April 14, 2009, 05:33:50 PM »
Hel brake lines
they run about $50 per line and you can get them in any color sheathe.. kevlar tubing, stainless webbing etc etc etc
ducrider45
Just Ride!
April 14, 2009, 07:05:53 PM »
I put a custom gauge on my 2000 M900Sie from Motogadget.
Thomas Jefferson
pitbull
April 15, 2009, 02:02:34 PM »
Quote from: Markus on April 14, 2009, 04:47:24 PM
www.motogadget.com
Pardon my ignorance, but what is the NOS unit? I did a little google-fu but couldn't find anything.
the ChronoClassic from Motogadget looks fantastic. Is it a fairly easy install?
Takster
April 15, 2009, 02:12:04 PM »
NOS = New Old Stock.
'09 Monster 696
pitbull
April 15, 2009, 02:47:52 PM »
Quote from: Takster on April 15, 2009, 02:12:04 PM
ahh......ok..........I thought it was a brand name of sorts........ I'm not always quick on the uptake
thanks
Takster
April 15, 2009, 06:11:41 PM »
Quote from: pitbull on April 15, 2009, 02:47:52 PM
thanks
If it isn't a new rugged cologne for men, it ought to be.
'09 Monster 696
weemonster
April 16, 2009, 05:27:21 AM »
i thought it was nitrous oxide.
i blame fast and furious.
Markus
April 16, 2009, 06:57:27 AM »
Quote from: weemonster on April 16, 2009, 05:27:21 AM
Sorry, I don't have any experience with the Motogadget Chronoclassic gauge. I just really really like the looks of it. If I was in the market for both gauges after my smashup I have ended up with that one for sure. As it was, my speedo was fine so i didn't have an excuse.
2000 M966Sie
2007 ST3s ABS
pitbull
April 16, 2009, 10:14:20 AM »
Quote from: Markus on April 16, 2009, 06:57:27 AM
actually, the gauges are ok..........it's just the housing that's smashed to bits.
I'm thinking some sort of custom housing.
