January 25, 2025, 07:50:36 AM
HyperPro RSC steering damper
Topic: HyperPro RSC steering damper (Read 6376 times)
"One-K-Duc"
April 20, 2009, 02:13:21 PM »
Anyone here have any experience with this one?? It claims "active" damping - looks cool - hoping to get some real world imput. Thanks in advance!
07 S2R 1000 Sil/Blk - NEW mods - Spark Full Exhaust (DP ECU, open airbox), Rizoma Bars, CF Belly, CF 996 fender, SpeedyMoto belt covers, dual headlights, home tail chop, Billet - brake/clutch res covers, alternator shaft cover, oil fill plug, shock racing mini LED markers, MadDuc open clutch, Paulimoto spider-ring, removed emmissions can, CRGs, DP gel seat, removed cupcake pegs
OT
Still Sweeping.....
Re: HyperPro RSC steering damper
April 20, 2009, 02:17:29 PM »
Pics? Linky to a website?
"One-K-Duc"
April 20, 2009, 02:18:46 PM »
http://www.hyperprousa.com/catalog.php?cat=Dampers&make=Ducati
1313
April 20, 2009, 02:37:10 PM »
Thanks for the link! That makes 3 steering dampers available for the 696. We're slowly catching up to the rest of you guys.
Ducati Performance ($658)
Kyle Racing ($449)
Hyper Pro USA ($479)
I really like the idea of Hyper Pro's "active"/RSC feature. It reminds me of the Koni FSD dampers for cars. It automatically adjusts to road conditions.
Last Edit: April 20, 2009, 02:42:55 PM by 1313
09 M696
2001cromo
April 20, 2009, 03:17:49 PM »
Quote from: "One-K-Duc" on April 20, 2009, 02:13:21 PM
I've got an RSC on my 2001 Monster. HyperPro only makes the RSC in the smaller 75mm stroke. All the others are the CSC.
I previously had a CSC and honestly I can't tell the difference in feel.
April 21, 2009, 01:30:20 PM »
does anyone know how it is 'active'?
S2R 800 '07
April 21, 2009, 02:11:20 PM »
Quote from: Raux on April 21, 2009, 01:30:20 PM
From their US website:
Active (RSC)
(Reactive Speed Control)
The HyperPro RSC is the only active valving damper available. As steering speed increases, the internal valving changes automatically to increase the damping effect. This results in a light, easy handling ride at low speeds while still keeping the heavy damping during extreme situations
I'm thinking about getting a damper and was curious about this unique "active" thing. Sounds like a good idea. Nothing for my bike though, side mount only for me - and those are not made as "active".
jesse370
April 21, 2009, 03:40:28 PM »
I have this on my Rs, and it is not the reactive type. As said that is only available in the shorter stroke version that a superbike would use.
But with that being said, the mounting kit is great and the damper is rebuildable and is amazing. I HAD a DP damper that was more expensive and failed within a year, and even when it was working wasn't near as nice as the hyperpro one I now have. Even on the side of the bike I can adjust it on the fly and with how I have it adjusted I have never found that is leave me wanting anything different.
White S4Rs | Ducati Performance Chip | Termi's | Hyperpro side mount damper | Motowheels MW-7000 Slipper | Billet Clutch Cover | Speedymoto Ti Spring Caps | Speedymoto Stainless Springs | STM Frame Plugs | Ducati Performance Seat | CRG Roll-A-Clicks
April 21, 2009, 09:46:39 PM »
Quote from: stopintime on April 21, 2009, 02:11:20 PM
Active (RSC)
hmmm again unless the damper is hooked to the speedo, how does it 'know' how fast i am going???
S2R 800 '07
April 21, 2009, 11:45:01 PM »
Quote from: Raux on April 21, 2009, 09:46:39 PM
It has a built in GPS
Not really - it's not about how fast the bike is going - it's about how fast the forks are moving. Normal steering is "slow" - hitting a pothole or having a tank slapper is "fast". Much like one would talk about suspension compression and rebound - slow movement or fast movement of the shock/forks.
April 22, 2009, 12:02:42 AM »
DOH, 'steering speed' not bike speed. i'm relating this to cars and how they use adaptive power steering based on the vehicles speed.
hypurone
April 22, 2009, 06:20:07 AM »
I have used Hyperpro exclusively up until I bought my pasta rocket. The RSC units work on the same principle as your forks/shock. It uses a multi stage orafice design which allows the fluid to flow thru a given orafice size to maintain proper damping. As the speed (piston stroke) increases, smaller orafices are closed by fluid pressure over the shim pack and fluid flows thru the next larger opening until that is overcome by pressure and so on and so on. All of this happens at speeds that boggle the mind so don't hurt yourself thinking about it.
A great unit and I would have bought another one for my RS had they made a top mount.
jesse370
April 22, 2009, 06:44:44 PM »
that is the problem, its a side mount.
April 22, 2009, 09:44:02 PM »
the 696 is a top mount. i really really like it. and the price seems better than the DP damper.
jesse370
Reply #14 on:
April 23, 2009, 10:34:36 AM »
Trust me when I say not only does the Hyper probably mount better it is a much higher quality part, that is rebuildable. And that is the reason I would recommend one over a DP damper.
And you will probably find it is priced in a much more reasonable fashion then the DP part. I really liked the DP unit I had while it worked, but a lifespan of less then two years is unacceptable on something that costs that much.
