April 28, 2024, 03:06:27 PM *
Author Topic: What the hell is wrong with my van???  (Read 2892 times)
Howley
« on: May 17, 2008, 12:40:51 AM »
I know this is not a moto topic but i figure it'll get more help here.
I have a Ford Econovan, it's a 2L carby petrol engine. Two days ago I'm driving it home and it starts dying. If I try to give it some gas it just won't fire, it's like the engine is still spinning but not sparking. If I keep accelerating it backfires massively. This is the case even when it isn't moving. The next day it seemed fine so I drove it, but it started doing it again after about 1km.
It's strange. It doesn't shudder or anything, it just makes zero power, engine stops revving, and it backfires. If I let off the accelerator it runs again. It starts and Idles fine.
I changed the fuel filter but that didn't do it. I thought it felt the same as my monster did when there was water in the carbs, and it was raining the day it happened, but the past two days have been fine and sunny and it still happens. I haven't checked the plugs because I don't have a wrench with me.
What could it be?Huh??
Online Online
« Reply #1 on: May 17, 2008, 02:44:55 AM »
It does sound like a fuel problem.  I would try these two ideas first:
Remove the top of the carb.  Inspect the fuel in the float bowl for contamination and fuel level.
Test the fuel pump for pressure and volume.
If there is junk in the carbs you will need to clean the fuel tank as well.
64duc
« Reply #2 on: May 17, 2008, 04:27:37 AM »
Change the fuel filter.
94 M900, 64 Diana 250
Online Online
« Reply #3 on: May 17, 2008, 05:23:05 AM »
I'd use drygas first and take things apart later.
Ddan
Some of my best friends are whores
« Reply #4 on: May 17, 2008, 09:56:16 AM »
Try running it with the cap off the tank
                    flogged successfully  NHMS  12 customized.  Twice.   T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
Howley
« Reply #5 on: May 17, 2008, 04:47:00 PM »
So it sounds like water in the fuel to you nate?
Online Online
« Reply #6 on: May 17, 2008, 05:28:49 PM »
It's the first thing I try when a rig suddenly acts like you describe.
It's cheap...and can't hurt anything if you add a small container to a tank of fuel.
It isn't always instantaneous though. Water can hide in a fuel system.
Rameses
*Your Mom* has a Hypermotard
« Reply #7 on: May 17, 2008, 06:42:35 PM »
It's probably b/c you're on the bottom-side of the world and your gas is dumping out of your float bowls.
 Tongue
For $50 you can touch my
« Reply #8 on: May 17, 2008, 11:00:06 PM »
 Tongue
He's right.
Turn the Van over.
Major Slow
09 1198s 07 S4R 04 FLSTFI 04 XL1200C 66 cl77
« Reply #9 on: May 18, 2008, 06:42:11 AM »
Check to see if your exhaust is plugged
You cannot argue with crazy because crazy is not willing to be convinced. Hell, it's not even willing to listen to the arguments.
