February 04, 2025, 09:58:49 PM *
Author Topic: Pro Taper SE bars on S2R 1000  (Read 4983 times)
vw151
« on: June 03, 2009, 05:37:43 AM »
Anyone running these.  I'm looking to get some bars that are close to the stock rise and pull.  Can anyone tell me what the rise and pull on the stock bars is?
http://www.motoworldracing.com/Pro-Taper-2005-SE-Handlebars.html
I bent a set of bars and thought these looked pretty cool, and strong.
vw151
« Reply #1 on: June 03, 2009, 06:19:21 AM »
The more I look, the more the contour or evo bar makes more sense since it seems to be a 1 1/8 inch center and a 7/8 inch control area diameter.  Now I just need to figure out the best rise and pull for my application.  I'm very tall so I'm thinking of keeping both pretty shallow but it would help to know the stock numbers to make a better guess.
woppini
« Reply #2 on: June 03, 2009, 07:43:19 AM »
I got the ATV high SE bars, along with 1.5 inch risers and they work great. I did have to get longer lines and cables made and extend the harness, but it was well worth it. No more neck and wrist pain and the bike is way more responsive. Im 5-10, so it worked out really well. PM me, and I can give you some pointers if you decide to do it
Stephen
S2R 800 '07
« Reply #3 on: June 03, 2009, 01:50:26 PM »
Stock sweep angle is 18 degrees. The height/rise depends on how they are rotated, but it's less than an inch.
clittelm750
Koketsu ni irazunba koji o ezu
« Reply #4 on: June 03, 2009, 06:03:28 PM »
I've got a set of Evo Carmichaels on right now .. it was kind of a pain to get em on - with the oversize bar and all I had to have the Pro Taper adapters milled down and a hunk of aluminum milled to get it over the forks but looks good and feels awesome
for long you live and high you fly but only if you ride the tide
vw151
« Reply #5 on: June 03, 2009, 07:47:14 PM »
I picked up some Henry/Reed contour bars today.   They mounted right up with the stock handlebar mounts.  there is something cool about having black dirt bike bars on there.  I am in process of getting the controls mounted up but it got late.  I'll post pics when I'm done.  It looks like I'll get away with stock cables and hydraulic lines but it did use up the slack that was in there.  Might get some separated brake lines in the future.
vw151
« Reply #6 on: June 04, 2009, 06:03:27 AM »
any of you guys got pictures.  Hopefully I'll finish installing tonight and have pics.
trpletme
« Reply #7 on: June 11, 2009, 05:19:21 AM »
I put a set CR High on mine and it pretty much used up the slack in the harness and cables but works fine and are much better than the stockers.
vw151
« Reply #8 on: June 11, 2009, 05:24:21 AM »
yah, same here on the slack.  I have a little more but not much.  I made a new thread with pictures.
http://ducatimonsterforum.org/index.php?topic=25085.0
Dink
Lov'in Every 2 Wheel Vehicle!!
« Reply #9 on: June 14, 2009, 06:48:04 PM »
I'm new to the Ducati Family and the site.  I just bought a 2003 Monster 800S ie.  I'd like to change the stock bars for,..  maybe Henry/Reed or CR High.  Something higher and with more pull back.  I though I saw a post where two guys used these and didn't have to change the cables or brake line.  Will Pro-Taper fit the stock base?  Anybody know for sure?  Also thinking about adding a Omar 1/4 Cafe Fairing.  Comments welcome.  Sorry if I've posted in the wrong spot, newby here.   Thanks
03 Monster 800S, 02 R1150R, Road
02 KLR 650, 02 DRZ 400 Dualsport
Lov'in Life on two wheels!
vw151
« Reply #10 on: June 15, 2009, 03:51:47 AM »
I don't know if the base for that bike is 7/8 or 1 1/8.  If the bar is not tapered then it's 7/8 if it is then it's probably 1 1/8.  My bars are the henry reed bend and I was able to use the stock brake lines and cables.
Dink
« Reply #11 on: June 15, 2009, 08:06:43 AM »
I'll have it this afternoon to know for sure the mount size.  Would you agree that the Henry/Reed is higher with more pull back or just the same as stock?  Did you mention the the cables and brake line are workable in stock length?  Thanks
vw151
« Reply #12 on: June 15, 2009, 08:26:58 AM »
definitely a little higher.  I think there is more pull too.  This is comparing against the stock bars on an s2r1000 though.  I don't know what the bars on a 2003 800sie are.  My s2r1000 bars were more or less flat.  Yes the stock cables, brake line and clutch line all worked with this style.  Either way, protaper has bars in 7/8 straight through or 1 1/8 tapered to 7/8 so you should be able  to find a bar that works for you.
Dink
« Reply #13 on: June 16, 2009, 04:37:57 AM »
Thanks loads,...  I put on some stock bars from a 02 ZRX-1200 and the have a 1" rise over the stock 03 M800S bars.  Felt more up-right, I think I'll run that for a while.
Spider
Ozmonsters: degenerating nicely since 2008
I may be long, but I fold up nicely
« Reply #14 on: July 31, 2009, 02:20:02 AM »
now what I want to see is the installed cross bar AND the protective pad! That would be different  Smiley
