September 01, 2024, 01:34:08 AM
Please Help
78
79
80
81
191
Topic: Plastic Tank problems: Discussion thread, see info thread sticky for updates (Read 699743 times)
herm
Re: Plastic Tank problems: Discussion thread, see info thread sticky for updates
Reply #1170 on:
December 01, 2010, 04:27:58 PM »
Quote from: Mhanis on December 01, 2010, 08:10:16 AM
Is this a question or a statement of fact? As an 1100 owner I have thought of this exact same thing; did Ducati "fix" the problem on the newer Monsters by using the above as a solution?
it was a question/suggestions.
however, as has been stated already, a non homologated tank is really not one of our options. but it sounds like a good idea for future tanks..
jgrm1
Reply #1171 on:
December 01, 2010, 06:48:59 PM »
How about Ducati coming up with a retrofit that would allow them to replace our plastic tanks with the previously used steel tanks? It seems to me that would be a relatively easy permanant fix. Wouldn't the previous steel tanks already have all the necessary certifications?
-Jeff
Last Edit: December 01, 2010, 06:50:49 PM by jgrm1
BMW: 2016 R1200RS, 2000 R1100S, 1975 R90S
Ducati: 2008 S2R1000, 1998 900 Supersport Final Edition
Norton: 1974 Commando 850
Triumph: 2016 Thruxton R, 1971 T120R
sbrguy
Reply #1172 on:
December 01, 2010, 07:02:07 PM »
but very expensive to make.
ithink the older metal tanks if you had to replace them new were something like 1800$ from a ducati dealer in the US.
best bet would be for the older monster plastic tank owneres to look for someone selling the metal tanks in good condition and then refurbish them and such and put them on, but like someone else said when you are done with getting all the parts to make it work it could work out to be around 1k-1.5k dollars to have it right.
Last Edit: December 01, 2010, 07:03:38 PM by sbrguy
jgrm1
Reply #1173 on:
December 01, 2010, 07:03:52 PM »
Sure, but look at the MSRP for our plastic tanks. The metal tanks were used in production for years, so the cost to Ducati could not be that prohibitive.
-Jeff
Last Edit: December 01, 2010, 07:06:42 PM by jgrm1
Reply #1174 on:
December 02, 2010, 03:35:35 AM »
Quote from: jgrm1 on December 01, 2010, 07:03:52 PM
-Jeff
The tooling for the steel tanks wouldn't add to the cost as it already exists...maybe.
The labor for a steel tank is what promoted the switch.
Reply #1175 on:
December 02, 2010, 05:12:09 AM »
There will be no metal tank to replace the deformed tanks. It will either be another plastic material or the same tank with a coating.
I would love to stop having to type this.
Reply #1176 on:
December 02, 2010, 05:17:20 AM »
Quote from: ducatiz on December 02, 2010, 05:12:09 AM
Maybe if you typed s l o w e r.
Mojo S2R
. Dark Mojo .
Reply #1177 on:
December 02, 2010, 09:26:45 AM »
And for those who are wondering, Steel and Aluminum are both metal. And - Yes, it will probably be a coating similar to the Caswell stuff (and others) mentioned throughout the thread.
Last Edit: December 02, 2010, 09:29:30 AM by Mojo S2R
My bike so far...
My desktop/wallpaper
CCMHA Map
Central Cal Monsters
duccarlos
Reply #1178 on:
December 02, 2010, 10:24:40 AM »
I suggest going back to the metal tank. Woops, I guess you didn't type it slow enough.
AMGnDuc
2011 Ducati Streetfighter S
Reply #1179 on:
December 02, 2010, 11:27:11 AM »
Just got authorization from DNA that my tank will be replaced. Pretty easy process overall. My dealer was great, took some photos and no hassles.
I just hope that the new tank fixes the issue. It would suck majorly if it happened again.
NorDog
I don't feel like a
Reply #1180 on:
December 02, 2010, 11:38:20 AM »
Quote from: AMGnDuc on December 02, 2010, 11:27:11 AM
Good luck with that.
I'm waiting for my third tank to arrive at the dealer.
I just don't understand why they don't use a metal tank. Something like steel, or aluminum maybe. I don't know, maybe it's just me.
arai_speed
Reply #1181 on:
December 02, 2010, 11:47:02 AM »
How exactly is a new tank, made the same way and with the same material going to fix the issue?
Unless you mean "fix the issue" TEMPORARILY...then YES...it will "fix" the issue
jgrm1
Reply #1182 on:
December 02, 2010, 01:47:41 PM »
Then stop typing it. I gave up sifting through this thread around page 60 in favor of keeping an eye on the concise update thread and did not see anything there about no metal replacements.
-Jeff
Last Edit: December 02, 2010, 01:49:54 PM by jgrm1
Reply #1183 on:
December 02, 2010, 01:48:59 PM »
Quote from: jgrm1 on December 02, 2010, 01:47:41 PM
-Jeff
thanks for the reality check, jeff. i'll update the other thread..
Bill in OKC
S4Rs
Reply #1184 on:
December 02, 2010, 02:45:27 PM »
http://www-odi.nhtsa.dot.gov/acms/docservlet/Artemis/Public/Pursuits/2010/PE/INOA-PE10045-8595.PDF
'07 S4Rs '02 RSVR '75 GT550 '13 FXSB '74 H1E '71 CB750
78
79
80
81
191
