Started by ducatiz, June 09, 2009, 12:56:37 PM
Quote from: Speeddog on September 23, 2015, 11:31:17 AM
I've got an '05 S2R800 tank that I've had hanging from the rafters in my shop for ~5 years.
I'm in SoCal, we've averaged 10" of rain per year during that time.
So it's pretty f'n dry.
It's still ~5mm too wide at the tank rubbers.
that is probably within normal variances.  the tanks deform a bit from heat too.
Quote from: ducatiz on September 25, 2015, 06:03:05 PM
Are we talking lawyer tolerances/variances...
or mechanic tolerances/variances? ;D
Quote from: ducpainter on September 25, 2015, 06:06:03 PM
probably both, but i've found the measurement to vary a bit.  the tank is flexible and the rubber frame stops have slots that allow them to move about 8-10mm to account for minor variance between tanks & frames.
Quote from: ducatiz on September 25, 2015, 06:29:32 PM
...and that is the way the steel tank parts were manufactured also.
It depends if the tank is 5 grand over nominal or maximum...
no?
...and if the max allowable on the rubbers only allow for + or - 4 or 5 mm it might be an issue.
Wouldn't you agree counselor? ;D
Airborne
I know I'm 190 pages behind in this thread, but I'm on my second tank. Never caswell coated, I just completely drain the tank with “the ultimate siphon” after every time I ride. I call it the bologna defueling procedure. It seems to work, when the tank expands I just let it sit empty for a while and it goes back to normal.
2007 Monster S2R, Vespa GTS 300, 2023 Triumph Tiger 900 Rally Pro, Vino 125
booger
I followed IZ's instructions to the letter, for a tank that sat without fuel in it for quite a few months to a year I can't remember. But the thing was dry. Washed it out best I could, hot water & Dawn. Let dry again. Cut the inside tank surface with xylene as IZ instructed. Coated it with Caswell after mixing a little xylene in to the mix as per IZ's instructions. No problems after about 3 years or so, or none that I notice with my naked eye. The space between the front of the tank and the ignition has remained the same. Not sure/ have not officially quantified the tank width but it looks the same. I even let fuel sit in it over the winters which I know I should not do but I do it anyway because I'm lazy. No problems. Going to stop leaving fuel in it because it's just so wrong but I have seen no problems at all. The coating process is a pain but it worked out for me. Take thy time and do it right, and your results might be same.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
