September 01, 2024, 01:40:42 AM
158
159
160
161
191
Topic: Plastic Tank problems: Discussion thread, see info thread sticky for updates (Read 699763 times)
K3V1N
Re: Plastic Tank problems: Discussion thread, see info thread sticky for updates
Reply #2370 on:
April 11, 2012, 09:27:14 AM »
Tank update:
The dealer called today and said they have to order the decals for the tank and wanted to double check on my color combo. Has anyone heard this before? Do they order the tank and decals then have them sent somewhere to be applied and clear coated?
Reply #2371 on:
April 11, 2012, 09:31:24 AM »
That's new.
ALl the tanks I've heard of had the decals on from the factory..
loves ze desmodromics.
Reply #2372 on:
April 11, 2012, 09:40:46 AM »
Quote from: ducatiz on April 11, 2012, 09:31:24 AM
That's new.
Every tank I unboxed at the dealership when i was parts mgr was 'pre-painted / pre-decaled' - you unbox, switch over the internals, and you bolt it to the bike. voila.
Africaboy
Reply #2373 on:
April 11, 2012, 10:21:55 AM »
I got my new tank today. It seems to me that the the nylon, I can see at the filler neck isn't as bright as on my previous tank. It is almost off-white. My dealer in Ontario, Canada, said this was the 1st Monster they have done. Thanks Izaak,
K3V1N
Reply #2374 on:
April 11, 2012, 12:26:01 PM »
Maybe the woman was just asking what color combo to order. I don't think they have the tank yet. It was just weird she did make it sound like she had to request the tank and the decals.
Reply #2375 on:
April 11, 2012, 02:37:52 PM »
Quote from: K3V1N on April 11, 2012, 12:26:01 PM
there is a separate part # for the tank (with decals) and the decals. she might be unaware of that.
CayoHueso
Reply #2376 on:
April 13, 2012, 07:19:53 PM »
If anyone is looking for a perfect condition METAL tank off a 2004 S4r.
PM me.
Betlog
Reply #2377 on:
April 14, 2012, 09:14:53 PM »
I took my tank out today to dry it up. Hopefully in the next month or so I will be able to Caswell. However, in looking at the inside of the tank, I noticed some "'craters" or "pimples" see below. Is this normal? Will the Caswell coating still work even though my tank has these? Also, when I do the Caswell coating, is it ok to do a couple of coats? I am thinking of making it thicker by applying one coat, letting it dry, then applying another coat. Thoughts?
DucNaked
Reply #2378 on:
April 15, 2012, 04:22:08 AM »
Quote from: Betlog on April 14, 2012, 09:14:53 PM
Mine had a bunch of those. They were soft and some had fluid trapped in them. I put it in a room for a couple of months with a dehumidifier. It shrank a little, but it never went back to normal and still didn't fit on the frame right. I wound up just getting a new one and coating it.
Betlog
Reply #2379 on:
April 15, 2012, 04:47:26 AM »
Quote from: DucNaked on April 15, 2012, 04:22:08 AM
Did the new one you got have them too?
DucNaked
Reply #2380 on:
April 15, 2012, 05:46:19 AM »
Quote from: Betlog on April 15, 2012, 04:47:26 AM
Not that I noticed.
Betlog
Reply #2381 on:
April 15, 2012, 07:42:49 AM »
Quote from: DucNaked on April 15, 2012, 05:46:19 AM
Not that I noticed.
Ok. Thank you.
jgrm1
Reply #2382 on:
April 15, 2012, 08:24:00 AM »
Yes, they do. The pimples result from manufacturing.
-Jeff
BMW: 2016 R1200RS, 2000 R1100S, 1975 R90S
Ducati: 2008 S2R1000, 1998 900 Supersport Final Edition
Norton: 1974 Commando 850
Triumph: 2016 Thruxton R, 1971 T120R
Reply #2383 on:
April 15, 2012, 09:18:46 AM »
"pop" as many of those as possible so the coating goes inside it. i used an exacto knife and cut the thin surface away. if your tank is used, lance them and then let tank dry again. all of the pa6 tanks I've seen have them.
Betlog
Reply #2384 on:
April 15, 2012, 10:38:05 AM »
Quote from: ducatiz on April 15, 2012, 09:18:46 AM
Thanks! What do you mean by "lance"?
158
159
160
161
191
