December 23, 2024, 04:30:03 AM *
Pages: 1 ... 168 169 [170] 171 172 ... 191   Go Down
Author Topic: Plastic Tank problems: Discussion thread, see info thread sticky for updates  (Read 714251 times)
duccarlos
« Reply #2535 on: August 28, 2012, 11:47:07 AM »
I believe Grifo has posted photos of the mount kit on this thread. I'm too lazy to look for it.  coffee
duccarlos
« Reply #2536 on: August 28, 2012, 11:51:03 AM »
The solution sucks doesn't it. That seat will end up being cut down to accomodate the tank swelling, then if the tank ever goes back to original shape the seat won't fit properly.  FWIW this FU band aid approach is all spelled out in the settlement, but it is my understanding that the dealer should do the correction at no cost to you. Seems strange to me that they would allow you to do it, then you could claim the kit if faulty. I'll defer to Ducatiz. - Gene
last I checked, Toronto is not part of the US. The settlement does not cover Canada. In theory, there could be a Canadian class action against Ducati.
Uncle Mofo
"Must Win Track Day" Uncle Mofo Racing 2007 S4RS
« Reply #2537 on: August 28, 2012, 12:17:35 PM »
Page 164  coffee
                                   2007 red S4Rs
mbld
« Reply #2538 on: August 28, 2012, 12:41:06 PM »
Page 164  coffee
Sweet, thanks!  Grifo, did you experience seat clearance issues?  I am assuming this only happens if there's a lot of longitudinal expansion...
Bill in OKC
S4Rs
« Reply #2539 on: August 28, 2012, 02:06:22 PM »
Yeah and other corn prodcuing states are the same way. None of the gas stations I went to in Indy had any E fuel, nor did the 2 stations I stopped at in West Ohio. - Gene
Those two states do not require labeling.  Here are two lists of states that do and do not require labels at the pump.:
http://www.fuel-testers.com/state_guide_ethanol_laws.html
twolanefun
« Reply #2540 on: August 28, 2012, 03:54:01 PM »
Thanks, I had no idea. Look at that stuff, looks to me like there is a whole bunch of places where you won't know unless you test it on the spot. What a mess all because of something that makes no sense anyway. - Gene
"I know a few roads"
92' PASO 907ie
02' M900 54K+ Miles
04' ST3 58k+miles - Sold
01' Victory Sportcruiser 30K miles, 04' Victory Kingpin - 111K+ miles
09' XR1200 - 15K+ miles
13' Diavel - 13K+ Miles Pay attention and things will be okay
EX-MSF Instructor, EX-President MAD
AMA Charter Life Member, Patriot Guard Rider
Victory Motorcycle Club, Charter Member
Patriot Guard Rider
« Reply #2541 on: August 29, 2012, 04:26:17 AM »
You can pretty much assume if the part of the US you are in is populated you are filling up with E10.
Uncle Mofo
« Reply #2542 on: August 29, 2012, 04:56:06 AM »
My seat still fit just fine
                                   2007 red S4Rs
twolanefun
« Reply #2543 on: August 29, 2012, 06:18:50 AM »
Seat problems will occur if you have to slide the tank backward so that the rubber bumpers on the tank fit the frame. That is why the rear tank bracket has slots. Everytime I post about this the more pissed off I get what a FU solution, settlement.  boo  boo boo boo- Gene
92' PASO 907ie
02' M900 54K+ Miles
Patriot Guard Rider
duccarlos
« Reply #2544 on: August 29, 2012, 08:04:43 AM »
Did you send Tiz your objection to the settlement when he requested it? if you did, then you should be pissed. By that point I was not in the country, so my objection was irrelevant.
twolanefun
« Reply #2545 on: August 29, 2012, 09:53:44 AM »
I sent mine directly. And I also sent a lengthy letter directly to DNA. They have lost the sale of two new ducati's, I'm keeping what I have, except for the S2R1000. - Gene
« Last Edit: August 29, 2012, 09:55:41 AM by twolanefun » Logged
92' PASO 907ie
02' M900 54K+ Miles
Patriot Guard Rider
duccarlos
« Reply #2546 on: August 29, 2012, 12:01:49 PM »
Like I said, in that case you should be pissed simply because you did as much as possible.
bmonty72
« Reply #2547 on: August 31, 2012, 05:42:26 PM »
 I was at my local dealership the other day, ordering tank #3.  I asked which new Ducati models had their fuel tank made from the same material... The answer was "pretty much all of them".  I love my Monster, but am I afraid I will not want to buy another Ducati until they find something better to use.  I try  to buy the higher octane fuel to avoid ethanol as much as possible, but there is always some fuel in the hose left over from the person who pumped gas before you.  If there is approx. a half gallon of fuel left over in the hose, I am getting 1/6th of a tank of Ethanol "enriched" fuel with each fill-up... bang head
Bishamon
« Reply #2548 on: September 01, 2012, 04:57:49 AM »
With my Sport 1000, I fill up my truck first, then fill a gas can, test the gas in the can for ethanol, then fill my Sport 1000 from the can.  I have successfully avoided ethanol, but this method would be quite a hassle with a daily ride.
2011 Monster 796
2007 Sport 1000 SE (SOLD) Sad
« Reply #2549 on: September 01, 2012, 05:32:50 AM »
For those of you who have uncoated tanks, I wonder if it would be possible to add a drain petcock to the tank.
Using E10 fuel is fine provided it doesn't sit in the tank.  If there was an easy way to drain the tank after a ride into a can, and then pour it back in when you're ready to ride, would you?
One of the "features" to be included in my aluminum tank is a drain.
« Last Edit: September 01, 2012, 05:37:04 AM by ducatiz » Logged
Pages: 1 ... 168 169 [170] 171 172 ... 191   Go Up
